I'm getting info on how to adjust which parameters and maybe that can be put in the table descriptions.
All info will be stuff we can use...no proprietry info...my own writing.
Howard
DUCT TAPE.
98 K1500 'HOLDEN' Suburban.
Don't know if this is generally 'known' info but it's fairly basic (which is what I personally need ) Hope this helps a few of you. I've been playing with the tables but really didn't understand them. I have managed to fairly dramatically reduce lean tip in.
1) when seeing lean tip in...Impact factor should be increased. A lean tipin is caused by more fuel impacting on the port wall than what was predicted.
2) When seeing a rich 'tip-out' (decel) spike....Impact factor should also be increased. More fuel is in the "puddle" on the port wall than what was predicted.
3) When should I adjust the boiling time constant and which way for which condition?
Change your boiling time constant only if you are finding that the period of transient compensation (the parabola of fuelling adjustment) is either too short, or going on too long.
As a general rule boiling constant should only be adjusted as a last resort as it will also effect the way impact factor works, which sometimes results in chasing your tail trying to get it right again.
A good way to learn this sort of stuff is to make the numbers really big and see what happens. Then make them really small, and observe what happens. There is no danger in doing this with transient fuel (unlike spark!).
Howard
DUCT TAPE.
No worries!
You know....I don't know if that 'basic' info is considered top secret by others....but I've scoured the net and HPT forums and I can't find that info ANYWHERE!
Found HEAPS of threads with people asking but every thread went around in circles and NEVER laid it out!
Howard
DUCT TAPE.
IMO rich tip out is caused by more fuel evaporating off the wall & entering the cylinder. So boiling time needs to be adjusted for this condition. Raising these parameters should decrease the amount of fuel injected & therefore reduce the rich tip out.
Note that the reduction in map (increased vaccuum) will also cause the fuel to evaporate faster off the port wall.
What I think is going to be the real trick is getting a good baseline for the transients at a set airflow/ect/map, & being able to dial in the modifiers. The other thing is are the modifiers at a set airflow or delta airflow? The scan tool links I have set up are for actual airflow & could be incorrect.
Last edited by 5.7ute; October 1st, 2008 at 08:00 PM. Reason: rambled on a bit more
The Tremor at AIR
Rev it up, Drop the clutch, See what happens?
Mick,
12593358.cax has . (dot) in front of B9006 and B9007... is that intentional...?
---> see post #5 on previous page showthread.php?t=9147
Joe
Joe,
That's how I disabled those 2 parameters as they did not look right, I think?...... I need to go over this one and 12205074 to tidy them up. I'm going to look at the scalers a little and fine tune them, they need to be a little more consistent. I am on it.
Cheers
Mick
