Results 1 to 2 of 2
Thread: injector pulse width for motron 60lbs
    May 2008
    Default injector pulse width for motron 60lbs
    What should i do with my IPW settings, i already fixed the IFR per the spreadsheet. Im currently running OLSD trying to tune the VE. But at idle it bogs and dies.
    Jun 2005
    For my car, I needed to get the final pulse width down to about 1.6ms. In order to do that, I had to drop the min. pulse width some, zero out the adder (looks like a backwards MAF curve), and tweak the voltage vs. MANVAC adder in the bottom few rows. Sorry I don't have the technical names - on a different computer. But, they're all in the injector folder.
    I'm still tweaking, so I don't know where I'll end up for sure. But from what I can see, this is something that you'll only be able to get close...not perfect. I think I also saw somewhere that these injectors will start to give you problems under a 1.2 or 1.3ms final IPW time. So, hopefully, you're not going to be too close to that threshold.
  1. (B3701) Injector Pulse Width values for SVO 42# Injectors
    By DrkPhx in forum General (Petrol, Gas, Ethanol)
    Last Post: September 13th, 2009, 02:56 AM
  2. injector pulse width max?
    By pero648 in forum Gen III V8 Specific
    Last Post: April 5th, 2008, 12:47 PM
  3. Small Pulse Adjust/Low Pulse Width Injector Offset
    By N0DIH in forum General (Petrol, Gas, Ethanol)
    Last Post: September 4th, 2007, 09:05 AM
  4. Injector pulse width
    By Bruce Melton in forum General (Petrol, Gas, Ethanol)
    Last Post: October 7th, 2006, 01:49 PM
  5. Minimum Injector Pulse Width
    By curtbriggs in forum General (Petrol, Gas, Ethanol)
    Last Post: May 11th, 2006, 11:28 AM
