Results 1 to 3 of 3
Thread: tuning question
    Jun 2008
    Default tuning question
    This efi live thing is pretty cool. I got my truck tuned and a buddy has a lb7 also. how can i get the same tune on his truck with his operating system???
    Can i just find the tables that are different from stock and copy them into his stock tune?
    Nov 2007
    you can manually copy and past the tables but it is easier to use make a script from your tunes and then run it on his stock tune. Here a good how-to on scripts http://www.dieselplace.com/forum/sho...hlight=scripts Just follow that to make a script from you stock and modified tune and then run it on his stock tune to make the changes. One thing you need to watch out for is changes in the fuel tank capacity and changes to the speedo pulses. If they end up in the script and you don't want them changed just open the script with note pad and delete those lines out.
    Jun 2008
    Hey thanks acrider that sounds a lot simpler.
  1. Question on C6 Z06/E38 tuning
    By Chalky in forum Gen IV V8 Specific
    Last Post: March 7th, 2009, 05:50 PM
  2. Tuning Question
    By esco35m in forum General (Petrol, Gas, Ethanol)
    Last Post: October 5th, 2007, 04:18 AM
  3. MAF Tuning Question
    By CGTMS in forum General (Petrol, Gas, Ethanol)
    Last Post: January 8th, 2007, 08:52 AM
  4. VE Tuning Question
    By SGCTS-V in forum General (Petrol, Gas, Ethanol)
    Last Post: April 23rd, 2006, 12:31 PM
  5. Tuning without o2s question
    By tuff in forum General (Petrol, Gas, Ethanol)
    Last Post: August 6th, 2005, 03:12 PM
