Results 1 to 3 of 3
Thread: Dumb question...
    Apr 2007
    Default Dumb question...
    Dumb question.
    I got a SD card today to start BBL. But, I'm stumped as far as how to change the pids you can montior on the Flashscan. It gives me a list to select, how do you edit it?
    Sorry for the stupid question. This is all new to me.
    2011 Chevy 2500HD LML 4x4 LTZ-Black
    -H&S Mini Maxx | MBRP 5" w/Muffler | 4" Rancho Lift | BMF REPR 20x9 DM | Mickey Thompson ATZ P3's 35/12.50's.
    2012 VW Jetta TDI - Daily Driver.
    SOLD - 06 LBZ
    EcoDieselRam Forum
    Jan 2008
    you have to manually type them in the options.ini file you load on the FS unit.
    You have to edit the file Options.ini located in C:\Program Files\EFILive\V8.1/Config...
    Then connect your V2 to your PC and run EFILive Explorer (EE), click on the Config tab, drag the correct .pmm file (for your ECM) from the upper pane (your hard disk) down to the lower pane Config tab (your V2).
    See these 2 sections of the readme file (see attached):
    • Configure FlashScan and/or AutoCal for BB logging
    • Using BB Logging
    V2 BBL only works if you have updated your V2 bootblock, or if it already came updated.
  1. New guy, dumb question
    By Pipeliner in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: December 14th, 2007, 07:20 PM
  2. Dumb question...
    By Cougar281 in forum Vortec V6/V8 Specific
    Last Post: November 7th, 2007, 08:55 AM
  3. Probably a Dumb question...............
    By FreddyG in forum Petrol / Gas
    Last Post: September 17th, 2007, 02:47 AM
