Results 1 to 10 of 15
Thread: Basic tuning question
    Jun 2008
    Default Basic tuning question
    I am new to efi live. got my truck tuned with it from a reseller with a small tow tune. But now i want to experiment a little.
    Are there just a few main tables that get changed with most tunes,or are there hundreds that must be changed?
    If theres just a handful of them could someone list them for me?
    Sep 2006
    At the top left of the page, click on "User CP" and fill out a signature about your truck...It will help us help you
    2007 CC/SB 4WD, McRat EFI Live, Trans, Trans Cooler and C3 clutch oiling mod by Mike L., SD Sleeves, SoCal Diesel
    2002 CC/DRW 2WD, McRat EFI Live, Trans, Trans Cooler and C3 clutch oiling mod by Mike L., SoCal Diesel
    Jun 2008
    sorry about that, maybe this helps
    2001 chevy duramax LB7 extend. cab short box 4WD
    EFIlive w/tow tune 285/75-16 dueler revos. pyro and boost , everything else stock.
    Sep 2006
    B0720, 0721, 0741, 0727, 0910
    Those should get you started...
    Jul 2007
    It may be a good idea to leave 0741 alone. I left that one alone in an attempt to keep it somewhat safe and have still limped my tranny three times. I'm not sure if tranny was properly cared for before I owned it, but I know I haven't so that may have contributed. If you want I can send you the tune I had in there last. I'm still learning too though. But that tune was fast and it would blow some smoke if I wanted it too.
    Jun 2008
    Hey thanks for the tips , sparky, I am still pretty jumpy about what I go to try in the truck, so if that tune was kind of hot I probably shouldn't even look at it yet until I get my bearings a little with efilive. But thanks for the offer!!
    Sep 2006
    I've adjusted B0741 on several trucks with a stock transmission, no limps...Some are stronger than others I suppose...
    1hotduramax, let me know if you need any help...
    Anyone here ever done performance tuning for better MPG? I have an idea to tune the fuel lower, adjust timing, and lower the boost, and see if there is a stable safe lower performance, lower fuel, performance level that I can tune it to, and then boost back to stock from there. Has anyone ever tried such a setup? Thanks, Gene
    PS: I don't have my dream motor yet, but I am thinking about doing this tuning for a Hot Rod project using a diesel 6.6L Duramax V8, or the new Duramax V6 that GM is coming out with, or the new V8 Cummins or the new V6 Cummins. Today, I have a 2002 Common Rail Cummins 4 cylinder (ISBe170), and I might be able to fiddle with that computer also. Thanks...
    Just an FYI, GMs new Duramax is going to be a V8 for sure, there are already prototypes out. 4.5L V8 with reverse flow intake/exhaust that fits inside a normal GM small block V8 package, this engine is destined to be swapped into lots of older rides to make lots of horespower.
    That sounds like a good idea, but why waste the $$$ on a Juice when you can just buy a FlashScan V2 and do tune switching on the fly with a few button clicks and have 5 custom tunes vs the generic Juice ones? Yes its only for the LB7 and LLY D-Maxes right now, but if thats what you're looking at IMO its a much better and more cost-effective way of doing what you're looking to do.
    Can someone explain to me how the FlashScanV2 works? I don't know much about them. What I need is the ability to push a button, and the tune changes to that setting. I can not ask a Hot Rod customer who knows nothing about the FlashScan to go through a reprogramming process. It needs to be dirt simple and work on the fly as they are driving.
    Can the FlashScan do this?
    Anyone live in Beaverton Oregon who can show me a working FlashScan system so I can see how easy it is to do?
    Thanks! Gene
    1949 Dodge Power Wagon Crewcab Project
    2002 Cummins ISBe170 3.9L 4 Cyl. Common Rail Turbo Diesel...
    NV4500 5 Speed, NP205 Transfer Case...
    14 Bolt and Dana 44 Axles...
    Dream motor might be a 6.6L Duramax V8 (LB7)
    503-627-5774 (Work)
    503-267-1648 (Mobile)
  1. Basic tuning question............
    By FreddyG in forum Gen III V8 Specific
    Last Post: June 16th, 2007, 10:03 AM
  2. Basic VE/MAF Tune
    By RevGTO in forum General (Petrol, Gas, Ethanol)
    Last Post: December 4th, 2006, 11:53 PM
  3. cam install basic tune
    Last Post: April 23rd, 2006, 06:31 AM
  4. Basic FAQ/Tuning Advice
    By mmorgan24 in forum General (Petrol, Gas, Ethanol)
    Last Post: April 13th, 2006, 03:49 PM
  5. Basic Tune Question
    By lplott in forum General (Petrol, Gas, Ethanol)
    Last Post: July 21st, 2005, 09:12 AM
