Results 1 to 4 of 4
Thread: sanity check of semil-OL OEM tune
    May 2007
    Default sanity check of semil-OL OEM tune
    Would someone be kind enough to quickly sanity check an OEM tune that I've turned to semi-open loop?
    I've also adjusted the PE enablers to be a bit more aggressive to come in earlier on the throttle.
    Thanks in advance
    Hi Mike,
    I would have changed B3610 to zero, but B3608 is zero, so it is irrelevant.
    B3616 below 3200 is ok; above 2800 is too aggressive.
    What is the kink in B5001...?
    Looks like you've correctly set it to run SOL; check the STFT's to verify that it does.
    Cheers
    Joe
    May 2007
    the 5001 was just as a result from the maf calibration, it could do with some smoothing but thats the consistent result from several runs (wo2 no longer installed...)
    I've smoothed out the tps now too, stft's look good but I'm thinking of taking off 02 feedback at idle
    May 2007
    actually racking memory that kink comes in at the range where the maf freq dropped off, ie no cells got counted above that part of the curve if I remember hence that little kink
  1. CALC.PID for simultaneous MAF & VE Calibration - need sanity check
    By Gelf VXR in forum General (Petrol, Gas, Ethanol)
    Last Post: January 7th, 2015, 01:33 PM
  2. Sanity check please
    By Forcefedperformance in forum Gen III V8 Specific
    Last Post: June 9th, 2010, 12:52 PM
  3. ls1 with ls7 maf, sanity check, input appreciated
    By rosey in forum Gen III V8 Specific
    Last Post: November 1st, 2009, 02:51 PM
  4. Sanity Check on Commanded AFR
    By Kevin Doe in forum General (Petrol, Gas, Ethanol)
    Last Post: October 23rd, 2007, 03:34 AM
  5. Sanity check, please?
    By critter in forum General (Petrol, Gas, Ethanol)
    Last Post: September 19th, 2007, 02:14 PM
