I want know if my trans is slipping at wide open in 1st and 2nd. I know 3rd gear you want your input and output should be same and 4th you be .7 from the output to the input. So what should 1st ans 2nd gear be. Here log file to look at. The wide open run is at end of the log file.
Thanks for the help.
