Page 3 of 3 FirstFirst 123
Results 21 to 25 of 25
Thread: BBL and fjo
  1. #21
    Its not really "instant". It will take about 10-20 minutes for a license turn around. But still better than 24 hours. And no more lost emails as the license details will be available in the online store account.
    Well, thats way better than 24 hours. Thats something you can order then go talk with the customer about what they want and then start right as you get the license...or start tuning then flash when you get it.
    Im pumped!
  2. #22
    you need to configure the options.ini file for the PIDs you want.
    location of the file:
    C:\Program Files\EFILive\V8.1\Config.
    "-", WO2AFR1
    "-", WO2LAM1
    "-", WO2ST1
    "-", BEN1
    You can add these to each pid list, or you can enable the external serial pids in the V2 options.
  3. #23
    Mar 2007
    which file in the folder is it ? it tells me i cannot open the files without the progam that created them? i dont understand how to add or open the files in that folder. its has things like LS1A and LS1B as file names?
  4. #24
    Nov 2006
    open EFILive_Explorer.exe> config files tab
    then navigate to C:\Program Files\EFILive\V8.1\Config.
    you copy/move all of these files to the V2.
    in the C:\Program Files\EFILive\V8.1\Config. there is the options .ini file
    that is the file to edit before you move it to the V2.
    you can do as Joecar suggested to show the WBO2 data but if you want to log
    you own define PID selection with BBL you will need to change the options.ini
  5. #25
    The analog AFR is not yet displayable on V2 BBL...
    The serial AFR will be displayable with the next release of V2 firmware 2.06.01 (I am told)...
    you will need a serial comms cable for connecting the FJO to V2.
