Page 1 of 3 123 LastLast
Results 1 to 10 of 25
Thread: BBL and fjo
    Mar 2007
    Default BBL and fjo
    i cant seem to find anything on bbl and fjo. how do i set up to display afr on my v2 using my fjo wb. do i need a specian cable or am setting it up wrong? a little help guys. thx
    Jan 2005
    Have you read this already?
    Nov 2006
    you need to configure the options.ini file for the PIDs you want.
    location of the file:
    C:\Program Files\EFILive\V8.1\Config.
    "-", WO2AFR1
    "-", WO2LAM1
    "-", WO2ST1
    "-", BEN1
    Mar 2007
    im still confused. do i need a serial cable for the fjo unit to display afr on the v2 or am i just setting up the files wrong? sorry i took so long to respond been busy at work.
    Mar 2007
    Quote Originally Posted by mr.prick View Post
    "-", WO2AFR1
    "-", WO2LAM1
    "-", WO2ST1
    "-", BEN1
    im sorry but how do i do this?
    You need a serial cable.
    You need to edit those into the Options.ini file (located under C:\Program Files\EFILive\V8.1).
    Mar 2007
    where would the cable plug into the fjo unit? and how do i edit. anybody sell a pre-made cable? any way you could give me some over the phone help?
    I'm not sure... does your FJO have a means of serial output...?
    Mar 2007
    thx. i sill dont understand how to edit the folder
