Results 1 to 9 of 9
Thread: support for vz v6 5 speed auto
    Default support for vz v6 5 speed auto
    does v2 had support for the vz v6 5 speed auto
    No, that is a weirdo Siemens TCM, you might be battling forever on that one.
    thanks ross
    try to read the pcm and tcm no luck at all
    Yeah, you won't get anywhere with it sorry. I'm not sure why they used that Siemens TCM when the T42 could have been used with the 5 speed and they were already using the T42 on the 4 speed (non SV6).
    make's you wonder what holden was thinking
    I'm curious if that is the 5L40E transmission...?
    Yes it is Joe
    Dec 2007
    Probably because that TCM is a BMW drop in on the part of GM?
    All of us Automatic Sky,Solstice,GT owners would like to see support for this transmission too, but it may never happen.
    I have bins from another source and have started trying to disassemble, but just WAY too busy at work to find a single free moment to get going let alone commit any serious time to it.
    Serious question: I wonder how hard it would be to swap out this TCM with a T42?
    If I could swap my Siemens out with a T42 and get tap shift to work I would be all over it.
    -Adam Chant
    Tune it or lose it!
    2007 Saturn SKY 2.4L Automatic - E67
    EFILive Tuned
    That TCM uses an Infineon CPU from memory, the same as our V2 uses!, but we program that in C, not assembly, so figuring out that TCM would be pretty tough for us. And in the whole scheme of this, it's usage is pretty limited.
    It would be pretty tough to get the T42 to run a 5L trans, I don't think a factory base cal exists (which makes it near impossible).
  1. PCM Support
    By SS2win in forum Gen III V8 Specific
    Last Post: January 12th, 2009, 04:53 AM
  2. LNF support?
    By Chunx in forum IL4, 97-01 PCM and 02+ P11 PCM
    Last Post: December 30th, 2008, 06:12 AM
  3. L76 support
    By limited cv8r in forum General (Petrol, Gas, Ethanol)
    Last Post: October 27th, 2006, 05:10 AM
  4. ls2 support
    By QUICKSILVER2002 in forum General
    Last Post: January 13th, 2006, 05:07 PM
  5. CAN support?
    Last Post: April 27th, 2005, 11:22 AM
