does v2 had support for the vz v6 5 speed auto
No, that is a weirdo Siemens TCM, you might be battling forever on that one.
Yeah, you won't get anywhere with it sorry. I'm not sure why they used that Siemens TCM when the T42 could have been used with the 5 speed and they were already using the T42 on the 4 speed (non SV6).
Yes it is Joe
Probably because that TCM is a BMW drop in on the part of GM?
All of us Automatic Sky,Solstice,GT owners would like to see support for this transmission too, but it may never happen.
I have bins from another source and have started trying to disassemble, but just WAY too busy at work to find a single free moment to get going let alone commit any serious time to it.
Serious question: I wonder how hard it would be to swap out this TCM with a T42?
If I could swap my Siemens out with a T42 and get tap shift to work I would be all over it.
-Adam Chant
Tune it or lose it!
2007 Saturn SKY 2.4L Automatic - E67
EFILive Tuned
That TCM uses an Infineon CPU from memory, the same as our V2 uses!, but we program that in C, not assembly, so figuring out that TCM would be pretty tough for us. And in the whole scheme of this, it's usage is pretty limited.
It would be pretty tough to get the T42 to run a 5L trans, I don't think a factory base cal exists (which makes it near impossible).
