When I go to real time when doing my VE table it still says RTACS is NOT ACTIVE.All the numbers are there moving
did you start emulation by clicking on the emulation icon?
did you select the fine or course setting for the table you are updating?
is the table linked to the PID(s) you want it to be? (cal.link.txt)
Mr Prick once told me this in the past and I blew right past it, so here is a graphic. Let me be explicit, RR WILL NOT ACTIVATE until either the FINE or COARSE control is selected. I also recommend activating the little blue tracking star next to it to track in the cells.
DEFINITION OF FINE/COARSE(TUNE TOOL MANUAL.PDF)
Fine: multiplier = 1-((1-PID)*(FINE/1000)))
Coarse: multiplier = 1-((1-PID)*(COARSE/1000))
Other notes:
- Once RTACS reaches the 1% target of your data, it will inactivate that cell unless
you set accuracy to 0%.
- Make sure RR is in Realtime mode.
- Check your filters before starting! make sure BOTH tabs of filter sets are what you expect.
- Make sure your RTACS lower limit is in a SAFE range for what you are working with. It normally takes the tables lowest and highest numbers.
07 Silverado DMax Classic
02 Z06 LS3 416, 805rwhp, TFS245, Wiseco, Callies Crank/Rods, Iskendarian Lifters, Crower Rockers, FAST102/90, ATI Damper, 1-7/8 Kook's LT, QkTime Shield,Tolle-Fab 8pt
Old Engine: 1/4mile = 9.6/146 New Engine:?
EFI Live Tune/Scan v7.5.27, EFI Live Scan and Tune v8.2.23, build 276, BootBlock 2.07.06, FirmWare 2.07.52, 512K RoadRunner (12.14.R), Innovate Serial LC2x2
COS5/12212156 For 2002 Z06 Manual Vette
Aaahhhhh the only thing I hit was the emulation icon.Thanks guy's......................Paul
What do you guys set your fine coarse settings to when doing VE??? the STD settings are way to slow..
my settings:
course - 100
fine - 50
update frequency - 5
