Results 1 to 10 of 12
Thread: MAP cells all the same colour????
    Jan 2007
    Default MAP cells all the same colour????
    Any reason when I look at my maps after logging....why they're all orange/red???
    Howard
    DUCT TAPE.
    98 K1500 'HOLDEN' Suburban.
    Oct 2006
    Subscribing.
    I definately preferred the cell shading in the older builds as an errant cell was easily identified at a glance.( Not that I make a habit of doing warp speed with an eye on the laptop)
    The Tremor at AIR
    Hmmmm (subscribing)....
    Jan 2007
    Ie...this is what one of my logs used to look like:
    And now....
    Howard
    DUCT TAPE.
    I see the same thing... later versions show less colour when value range is small.
    I pm'd Paul.
    Hiding empty cells can cause that. But I can see from the display that you have not got "hide empty cells" set. So I'm not sure what might be causing it.
    Can you email me (paul@efilive.com) the log file that produces the problem with a link to this thread?
    Jan 2007
    Thanks Paul....email sent.
    Howard
    DUCT TAPE.
    Lifetime Member jfpilla's Avatar
    You can create more differentiation by choosing colors in Map Properties.
    2003 red vert
    Mods:
    LPE 100mm MAF
    RPM Level 6/4L60e trans
    3.42 gears
    Yank SS3600
    1-7/8" AR headers
    Z06 exhaust
    470rwhp 437rwtq
    Lifetime Member Aloicious's Avatar
    Nov 2007
    I pm'd Paul.
    yeah I've noticed the same deal also in the latest releases. I'd be interested in the solution
    Oct 2006
    Bump
    The Tremor at AIR
  1. How to select mutliple cells in a row to smooth?? but not all of the cells.
    By 2010 Bumblebee in forum General (Petrol, Gas, Ethanol)
    Last Post: April 29th, 2010, 03:34 PM
  2. Reset Tap Cells
    By jaydog in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: January 23rd, 2009, 08:05 PM
  3. Highlighted Cells?
    By purrvert in forum General (Petrol, Gas, Ethanol)
    Last Post: May 30th, 2007, 02:17 PM
  4. PLX WB reading 13.6-13.62 in all cells
    Last Post: May 19th, 2006, 04:16 PM
  5. How do we hide cells ?
    By johnv in forum General
    Last Post: September 8th, 2005, 02:20 PM
