How can I force(if possible) my Vortec controller into Open Loop? Is it possible to run Vortec OS's in SD mode?
FLASHSCAN V2 & AUTOCAL
Nevermind, I got it (OL) DAMN!!!SD is the shit
Well after attending the EFI Live class in Temecula, CA this past weekend I figured out that I was never in SD mode:( just no MAF(wrong parameters enabled & disabled) Has anyone succesfully gotten a Vortec 98-00 pcm in SD. I'm really regretting using my 1998 s-10 V6 as my guinea pig...I should have used an LSx based vehicle with a V8...dangit
I was going to try to attemp the auto ve but there are quite a few tables missing in the Vortec controller as opposed to the LS1 type controller...
If you have no maf on your vehicle then it is in speed density if it is running.
Really... Man, I'm confusing myself. I guess what I was trying to do is put my truck in SD via the autove tutorial. That's when I figured out that most of the tables, that are talked about or referenced to, in the Autove tutorial, weren't available in the Vortec Controller...
Gameover, can you log commanded AFR? If so you may be able to do an AutoVE on your PCM. Disconnecting the MAF and both front O2 sensors will put the engine in open loop/speed density. It might not like it, but you can try. Log the Map, RPM, BEN, and commanded AFR. Create a map and see how it does. You might have to ignore DFCO enleanments. Of course repinning your harness and going with the 411 PCM would make the AutoVE process and other tuning much easier.
Al
Yes, I can log command AFR. I will give it a try. Thanks.......
Chips by Al,
Thanks...I got it to run in SD-Open Loop. My truck wasn't too bad. It was very drivable. WOW... Measured AFR(11.5) Command AFR(14.63).........
EDIT: *measured AFR 15.5* *command AFR 14.63*
