Results 1 to 2 of 2
Thread: I am getting no power to crank position Green B+ wire???????
    Jun 2005
    Default I am getting no power to crank position Green B+ wire???????
    My ls1 in my 71 chevelle does not run! :bang: I am not getting a crank signal.
    I tested wire #2 coming out of the pcm blue harness (LT GREEN, CRANK POSITION SENSOR B+ SUPPLY)
    It has no power. I tested my 2004 6.0 chevey truck green wire at the sensor and it has constant power with key on or off.
    What could make this terminal on the pcm not have power for the sensor? Some kind of theft shutoff program? I turned of the vtd on the pcm( or so I thought) ANything else I have to do??
    I checked ALL switched and constant positive and ground wires running to the pcm and they are all getting power or are grounded correctly.
    Why is this wire not getting power?
    '71 chevelle
    Twin turbo ls1
    1000 HP 93 octane street car!
    96 lb injectors
    Jun 2005
    It runs!! I found a broken wire of all things! Now I just hope I can get some tuning help real soon. Thanks!
    '71 chevelle
    Twin turbo ls1
    96 lb injectors
  1. Pedal position vs. commanded TAC position weirdness
    By gmtech16450yz in forum E37, E38 & E67 PFI ECM's
    Last Post: November 1st, 2009, 12:48 PM
  2. F302 Green Top Injector Specs
    By white01ss in forum General (Petrol, Gas, Ethanol)
    Last Post: August 13th, 2009, 05:01 AM
  3. E38 Crank Position Sensor Relearn
    By hapnermw in forum Gen IV V8 Specific
    Last Post: May 2nd, 2009, 04:58 PM
  4. new dumb and green
    By slowtruck in forum General (Petrol, Gas, Ethanol)
    Last Post: December 10th, 2006, 12:28 PM
  5. End injection point relative to crank position
    By joecar in forum General (Petrol, Gas, Ethanol)
    Last Post: January 27th, 2006, 02:02 PM
