Results 1 to 8 of 8
Thread: Programming window - V1 commercial
    Apr 2008
    Default Programming window - V1 commercial
    Don't know how it happened, but somehow the programming window got resized much larger than it used to be - can barely see/use the buttons at the bottom of the pc screen now - what did I do and how do I fix it?????
    Bird
    Bird,
    Welcome to the forum...
    Do you mean the tunetool or the V1 BBL programming window...?
    Did you change your screen resolution or text size...?
    Can you post a screenshot.
    Apr 2008
    Bird,
    Thanks for the welcome - been lurking and reading for quite some time. I'm referencing the programming window in the tunetool - where you retrieve / upload tunes from the PCM - haven't touched a thing and it looks to be specific to the tune files I'm using for my SS Camaro. If I start a new tune for anything else, that window is perfectly 'normal' and fit's in the screen.
    Haven't touched a thing on the resolution / text size.............. all I can figure is that I managed to hit some key combo that enlarged it. Will post up a screen shot when I get back to my laptop.
    Bird
    If you can get to an edge of the window, the cursor should change to the resize cursor, you can then make the window smaller... but I take it you can't get to an edge...
    Apr 2008
    no action when I lay the cursor on an edge...................
    Is Windows booting up in FailSafe mode...?
    Apr 2008
    Nope
    Post a screenshot when you can.
  1. V1 Commercial to V2 Commercial Upgrade
    By ls698ta in forum FlashScan V1
    Last Post: November 29th, 2010, 08:25 AM
  2. Window 7 demo
    By Chevy366 in forum Lounge
    Last Post: November 1st, 2008, 06:18 PM
  3. Menus: Window.
    By curtbriggs in forum General (Petrol, Gas, Ethanol)
    Last Post: February 28th, 2005, 05:00 PM
