Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: MAFless??????
    Ah, the tutorial you are reading is aimed at the LS1.
    As suggested above there is one for the E38, look in the Tune Tool help menu under tutorials for 'Virtual VE Tutorial'. Whilst the concept is the same, the way the VE table is changed is different to the LS1.
    Also, please see this thread -
    http://forum.efilive.com/showthread.php?t=8961
    Sep 2008
    Thanks GMPX I will check it out.
    Feb 2019
    The "Virtual VE Tutorial" is no longer revalent. It was written in 2007.
    Yes principle is sorta the same but table references are wrong and the newer tune version has different options/descriptions.
    Why can't these tutorials be updated?
    LS3 Manual 6 spd E38 os:12633056
    Texas Speed 1 7/8" headers w/3" exhaust
    Texas Speed cam 229/236 .629/.615 112 LSA
    Hi-Ram intake stock injectors 90mmTB
    Jul 2003
    The E38 is a different animal when in VE. There are a few of the dynamics variables that are not used when in VE and changes quite a bit the fueling. You need to keep this into account.
    Feb 2019
    Thanks Highlander, I agree...but still that's even more reason to update/create a tutorial for the E38 VVE. Seems like there is enough discussion to warrant a tutorial. I know the LS1 was much easier ( as related to the LS3) to tune, but there are a lot of 2009-2014 being modified. Is it we don't have enough knowledge base to create the tutorials like they did for the LS1? I do appreciate whats out here but there are still to many references to the LS1 tables making it hard for 2009+ users to understand. Then there is the conflicting explanations I run into that make it more confusing but I know there will be those discussions because of the level of understanding.
    I am still gonna keep digging and trying to learn this E38 ecm. Thanks to all for the help!
  1. Going MAFLESS and O2 less
    By The Alchemist in forum E37, E38 & E67 PFI ECM's
    Last Post: February 12th, 2008, 08:08 AM
  2. Going mafless On a E-40...anytips?
    By FFP in forum Gen IV V8 Specific
    Last Post: August 13th, 2007, 05:40 AM
  3. Question about going MAFless
    By VortechC5 in forum General (Petrol, Gas, Ethanol)
    Last Post: September 26th, 2005, 01:24 AM
  4. mafless/pcm
    By zrx1200 in forum General (Petrol, Gas, Ethanol)
    Last Post: January 25th, 2005, 12:48 PM
