Results 1 to 3 of 3
Thread: Innovate LM-1 Voltages.
    Jan 2005
    Default Innovate LM-1 Voltages.
    EFILive Scan Tool, page 101, show voltages for the LM-1 as 0V to 5V for Zero to 50 values.
    I programed the LM-1 controller for 0.5V for 10 AFR and 4.5V for 18 AFR. These values from the forum were PLX numbers and used for the LM-1. I assume because the LM-1 values weren't available.
    Wouldn't the new values for the LM-1 with the 0 to 50 values give more accurate readings?
    BTW, for the LM-1 Analog Output, I used pin C for the white wire (EXT. AD2). Pin D for the GND. Pin E for the Red wire (EXT. AD1) to the 3 pin block on the FlashScan.
    What say you.
    Thanks, Curt
    99C5, mn6, Vortec T trim, Snow meth injection, AFR 205s, ARP studs,Comp 224*112*+2*.580", YellaTerra RRs, PRC Ti's w/dbls, Supermaxx LTs, No Cats, Corsa Indys, LS6Intk, Hurst, Fikse Aro18"s. Pilot Sports 315/30,265/35, 04ZO6 Shocks Hotchkis bars, EBC YellowStuff pads, SS hoses, LM-1, EFILive, 2002 OS. RPS dual disc Clutch, DTE Strut Brace & output shaft.
    By default, the LM-1 outputs 0 to 5V to represent 0-50 AFR. The LM-1 PIDs in EFILive V7.3 are configured to work that way.
    However, you will normally only see AFR in the range 10-20, it makes sense to reduce the range of the AFR to increase the precision.
    I recommend setting your LM-1 to something similar to the PLX where:
    0V=10:1AFR and 5V=20:1AFR
    Then you would of course have to use the PLX PIDs (or alter the LM-1 PIDs in sae_generic.txt to match).
    Jan 2005
    Glad you said use the PLX pids, I already had the LM-1 pids selected.
    Thanks again for the quick reply, Curt
  1. DSP5 not switching voltages
    By lakingslayer in forum Duramax LB7
    Last Post: May 26th, 2010, 01:49 AM
  2. DSP5 Voltages
    By ruralgas in forum Duramax LLY
    Last Post: May 17th, 2010, 05:36 PM
  3. the innovate LM-2
    By A.O.A in forum General (Petrol, Gas, Ethanol)
    Last Post: September 3rd, 2009, 02:22 AM
  4. Innovate and MAP.
    By tgeers in forum General (Petrol, Gas, Ethanol)
    Last Post: August 11th, 2006, 11:06 PM
  5. Innovate LC-1
    By lplott in forum General (Petrol, Gas, Ethanol)
    Last Post: August 19th, 2005, 06:35 AM
