Results 1 to 4 of 4
Thread: selecting pids files ?
    Aug 2008
    Default selecting pids files ?
    hi everyone i cant seem to select any pids from the v2 to rec data -ive updated to 8.1 im sure ive followed instructions correctly with updating the film ware and bootblocker plus transfured the files from Config File system to config tab formated the 2G sd card i press on select pids and shows "options ini not found "??????
    You have to copy the Options.ini file using EFILive Explorer (EE)...
    with EE open, drag the Options.ini file from the top pane (folder C:\Program Files\EFILive\V8.1\Config on your hard disk) to the lower pane Config tab (the Config directory on your V2 internal flash memory).
    Aug 2008
    cool i think im missing the options ini folder from the config /c; on hard drive.....i have tried to repair no luck...hold the phone ive found the options folder dragged into Config tab not aprob thanks joe
    Oh, it might be in the folder C:\Program Files\EFILive\V8.1\Programs... oh, you found it...?
  1. selecting PID priority
    By Eric in forum General
    Last Post: January 15th, 2010, 03:24 AM
  2. Calculated PIDs not loading with BBL files
    By kp in forum FlashScan V2 BB Logging
    Last Post: June 2nd, 2009, 07:12 AM
  3. Need Help Selecting PIDs in BBL
    By dinorex44 in forum Black Box Logging
    Last Post: May 10th, 2009, 03:18 AM
  4. selecting pids on v2
    By Aint Skeered in forum FlashScan V2 BB Logging
    Last Post: December 9th, 2008, 03:44 AM
  5. Selecting PIDs
    By mnotx in forum FlashScan V2 BB Logging
    Last Post: September 6th, 2008, 12:12 AM
