Page 26 of 26 FirstFirst ... 16242526
Results 251 to 253 of 253
Thread: Flashscan data logging..
  1. #251
    Make sure the EFILive_Hapi.exe file exists in the \Program Files\EFILive\V8 folder.
    Make sure EFILive_HAPI is installed and can be run without any permissions problems. It is normally started automatically whenever any EFILive software attempts to communicate with FlashSCan or AutoCal.
    There should be a start menu entry that allows you to run EFILive HAPI in standalone mode: Start->All Programs->EFILive->V8->EFILive HAPI, try running it from there. It should start up and place itself on the system tray at the end of the Windows Task Bar.
    If it does not start or it starts and then terminates, it is most likely a Vista permissions problem. Try re-installing the V8 software.
  2. #252
    Except I just took another look at the screen shot and its XP, not Vista. So we can pretty much rule out a Vista permissions problem
  3. #253
    Lifetime Member waterbug1999's Avatar
    Mar 2008
    got it, thanks
    1999 Trans Am. 10.71 @ 126 - stock bottom end-
  1. BB Logging - Missing Data ?
    Last Post: July 24th, 2009, 01:01 PM
  2. Flashscan not responding when trying to data log
    By 99TransAmls16spd in forum General (Petrol, Gas, Ethanol)
    Last Post: March 11th, 2008, 07:25 PM
  3. V1 Data logging
    Last Post: December 2nd, 2007, 07:01 PM
  4. Data logging a 98
    By minytrker in forum General
    Last Post: February 25th, 2006, 02:10 PM
  5. Data logging
    By never satisfied in forum Duramax LB7
    Last Post: February 20th, 2006, 02:53 AM
