Results 1 to 4 of 4
Thread: Cant perform relearn..help
    Oct 2008
    Default Cant perform relearn..help
    Any ideas what I am doing wrong?? 411 PCM running cal from 2002 chevy express l31. 12212156 OS
    Temp--180
    VSS--0
    TPS--0
    Trans in Park
    Only DTC reported is P1336 it is listed a few times.
    Hit F12
    Choose 99-08 PCM
    Hit activate
    Learning Tab
    Hold brake
    Hit CASE
    EFI Live does nothing when I hit the CASE button????
    After clicking case the re-learn procedure requires that you raise the engine revs to 4500-5000rpm (over about 1-2 seconds) until you hear the fuel cut momentarily. Then let off the throttle and allow the engine to return to normal idle speed. Then ignition off for 15-30 seconds to allow the ECM to save the learned data.
    Oct 2008
    does EFI live do anything after the CASE button is pressed? I hit it and nothing at all happens
    Nothing that you will notice. EFILive sends the CASE learn command to the vehicle. The vehicle then waits for the operator to perform the CASE learn RPM increase.
  1. Help!! No idle and can't perform crank relearn
    By onegonewild in forum Gen III V8 Specific
    Last Post: October 16th, 2008, 03:42 PM
  2. cant perform relearn
    By slow89irocz in forum Gen III V8 Specific
    Last Post: October 16th, 2008, 02:51 PM
  3. Cant perform full OS reflash
    By Cobra#3747 in forum Duramax LB7
    Last Post: June 5th, 2008, 04:13 AM
  4. How do I perform VATs to BCM Relink?
    By KAZ MotorSports in forum Gen III V8 Specific
    Last Post: May 12th, 2008, 12:41 AM
  5. CKP Relearn
    By 91LS1S10 in forum General (Petrol, Gas, Ethanol)
    Last Post: November 29th, 2006, 08:21 AM
