Thread: Egt's
    Jun 2008
    Default Egt's
    How high is too high?
    I just loaded a tow tune a very mild one about 30 hp. WOT I have seen 1200.
    I want more power!! How high can you go and still be safe???
    2001 chev d-max lb7 all stock except efilive
    2001 chevy duramax LB7 extend. cab short box 4WD
    EFIlive w/tow tune 285/75-16 dueler revos. pyro and boost , everything else stock.
    Jul 2007
    I think you're fine. You won't be at 1200 sustained. I've seen as high as 1400 on mine WOT from a dead stop.
    Nov 2007
    I have buried my 1600 gauge when sled pulling. The main thing is you don't want them hot (say above 1300-1400) for an extended period of time. short runs you should be ok.
    '04 LB7, AEM Brute Force HD Intake, 4" into 5" single stack, Kennedy Boost valve, EFILive
    Jun 2008
    Thanks for the info! I can see this need for more power won't be stoppin real soon.
    Mar 2007
    That is high if your only adding 30hp your timming plays into how hot it will get.
    Senior Member DmaxHawk's Avatar
    Apr 2008
    There have been guys that have claimed up to 2000 degrees pulling and still nothing is wrong yet.
    07 El Bee Zee
    Little faster than stock...
