Results 1 to 3 of 3
Thread: Can't scan LLY in passthrough
    Default Can't scan LLY in passthrough
    V7.5.4 Build 66
    V2 FW 2.05.20
    I was going to try logging RPMs on my LLY while disabling injectors, but with only RPM (SAE.RPM) selected, I get the message "One or more _DMA PIDs are selected. This Duramax ECM can only scan _DMA PIDs in Dynamic or Stream Scan Mode. Please change the scan mode to Dynamic or Stream (menu: Edit -> Properties -> Logging -> Scan mode) before loggin _DMA PIDs." (logging is spelled wrong ) The problem is it was in either Dynamic or stream-fast (I don't remember which), I tried Dynamic, Stream-Slow, and Stream-Fast and all got the same message. Also, SAE.RPM isn't even a DMA PID, is it?
    It may be EFILive is trying to use Generic scan mode because only 2 PIDs were selected. Try selecting enough PIDs to use 6 or more channels.
    On the [Console] tab page, you can see the actual scan mode that EFILive "thinks" it should use. It may be different than the requested scan mode in the Properties window.
    For example, if you have stream-fast mode selected and only select one (or two) PIDs, EFILive calculates that it would be faster to log using generic scan mode than stream-fast. So it will use generic mode in that case.
    I'll fix the spelling error - thanks.
    I'll have to investigate why it thought it was logging DMA PIDs.
    That seems to done it... Thanks Paul.
    On another note, think it might be possible at some point to have marks entered in the log file when injectors are turned off to make it easy to see on the RPM Log, OR will the automated balance test work on the Diesels?
  1. LBZ/LMM Passthrough issues
    By Cougar281 in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: June 3rd, 2010, 11:55 PM
  2. V2 in passthrough mode
    By Tre-Cool in forum FlashScan V2
    Last Post: January 15th, 2010, 04:16 AM
  3. PID Availablity problems in passthrough logging mode.
    By XLR8NSS in forum FlashScan V2 BB Logging
    Last Post: November 29th, 2007, 01:45 PM
  4. Passthrough data logging problems
    Last Post: November 28th, 2007, 04:23 PM
  5. Problems with upgrading V2 from scan only to scan and tune...
    By DngrZne in forum General (Petrol, Gas, Ethanol)
    Last Post: November 26th, 2006, 03:41 AM
Tags for this Thread
