Results 1 to 3 of 3
Thread: Smoker Tune?
    Oct 2008
    Default Smoker Tune?
    My truck was tuned for mpg. The tune works very well as I am getting over 20 mpg. My question is it is a 100hp tune and I want to make a a twin to this tune for smoke. So do I go and max out the maf sensor or what is the best thing to get smoke with out adding more fuel to this tune? thanks for your help as I am new to EFI Live.
    Four stroke diesel S.S.B.B. Suck Squeez Bang Blow
    06 LBZ with 5 inch magnaflow exhaust,Bd exhaust manifold, Bully dog outlook, Egr blocker, Firestone air bag system,Custom sound system, dual fuel filters,leveling kit, B&M deep tranny pan,TTS lift pump,Turbo Resonator plugged,Cooper ST 265/75R16, Bully nerf bars and B&W guardian headache rack sprayed with reflex bed liner, B&W turn over ball,B&W Tow&Stow, transgo jr, efi live Tuned By IdahoRob,tranny filled with transynd
    WWW.ATPTrucks.COM
    Junior Member 06Dmaxpwr's Avatar
    Nov 2007
    Depending on whats been done to the fuel and boost tables already on that tune, I would copy you stock boost tables into that tune and then bring the maf up...you'll get some smoke especially if you drop even more than stock boost #'s
    Andy
    Senior Member DmaxHawk's Avatar
    Apr 2008
    Quote Originally Posted by 06Dmaxpwr View Post
    Andy
    X2 on bringing up the MAF. But its pretty hard to get smoke just with the maf. I've tried to just max out the MAF but it didnt really do too much on mine. Easiest way to get smoke is open up the pulse width and keep stock boost table or lower the boost like mentioned above. Smoke=fuel so adding fuel is almost a must.
  1. Replies: 5
    Last Post: August 5th, 2008, 02:35 PM
  2. Tune VE and MAF tables or leave VE stock and tune MAF only
    By BlackGMC in forum Gen III V8 Specific
    Last Post: August 4th, 2008, 08:05 PM
  3. What else can I tune without scanning or black boxen it? Tune history inside.
    By Round Rock TJ in forum General (Petrol, Gas, Ethanol)
    Last Post: May 3rd, 2007, 02:27 AM
  4. Convince me to change to a 2bar tune...709rwhp through an EFI maf tune.
    By onfire in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: June 16th, 2006, 12:04 PM
