Results 1 to 10 of 12
Thread: Flashscan Won't LOG ANYTHING valid PID's too????? Help
    Lifetime Member MN C5's Avatar
    Mar 2005
    Default Flashscan Won't LOG ANYTHING valid PID's too????? Help
    Installing the updated Version of EFILive corrected the problem. Thanks For All the Help
    VIN # 2GTEK638071697432
    OS # 12614088
    Calibration # 12614085
    Calibration Definition File (*.cal)
    Name 12614088.calz
    Version 7.21
    So I got my supercharger on and want to tune it only to find I can flash and read tunes but Flashscan won't read or log any data.
    It connects and validates the PIDS but doesn't display data or log it. Upon this first happening I was using a older build (#62 or something close). So I've now upgraded to build #66 and still Flashscan isn't working. Does it have some thing to do with the cal files... Help it feels dangerous driving without being able to see knock ect..
    Dennis
    Dennis,
    Did you select pids...?
    Post some pics of your various tabs.
    Mar 2005
    I think so.... I've attached a excel spreadsheet with 4 screen shots. PID's, Data, Console & Dashboard.
    Any help would be appreciated.
    Dennis
    Mar 2005
    I reflashed my OS from a Chevy PU to a GMC Denali on my ECM and didn't reflash the TCM. The TCM has a different reported VIN than the ECM. Could that be the problem?
    Fudge...
    Mar 2005
    Anyone ? ? ? ?
    On the Console tab, it says "Interface not detected"...
    Check your connections...
    Try Fast Stream mode (edit: I see it already is).
    I pm'd tech support.
    Mar 2005
    TTT...
    I bumped TS... Paul will get back to you.
    Did you press the red record button...?
    Mar 2005
    Yes, tried both the red and yellow buttons. Same thing with both, nada...
  1. AFR_NGK1 pid not valid
    By sixltrbtr in forum General
    Last Post: February 16th, 2010, 05:30 PM
  2. E38 = Not valid PID's
    By MN C5 in forum General
    Last Post: July 7th, 2008, 11:34 PM
  3. all pid not valid ? tuning issues
    By joe'sls1 in forum Gen III V8 Specific
    Last Post: September 26th, 2007, 05:09 AM
  4. Commanded AFR not a valid PID?
    By Rocketman69 in forum Vortec V6/V8 Specific
    Last Post: February 15th, 2007, 01:10 AM
  5. Valid & non valid pids
    By driver456 in forum General (Petrol, Gas, Ethanol)
    Last Post: April 24th, 2006, 10:22 AM
