Results 1 to 5 of 5
Thread: V7.5 Flashscan not compatible with V2?
    Feb 2007
    Default V7.5 Flashscan not compatible with V2?
    After downloading and installing V7.5.4.66 every time I try to log it says:
    "The FlashScan V2 interface is not compatible with this version of EFILive software. Please upgrade the EFILive software on your PC or laptop to the latest version."
    Whats the deal?
    Has it ever worked (in previous sfotware versions?).
    Normally with a software update the V2 firmware must also be done.
    Feb 2007
    Yes it works fine with 7.3
    I am looking at the Fashscan V2 section and the sticky on how to upgrade the firmware now, thanks.
    TxC, welcome...
    Did you also install the new V8.1...?
    Before you do the upgrade, read and understand the readme.txt fully before proceeding.
    showthread.php?t=9265&highlight=firmware
    Feb 2007
    I installed all the latest versions and it works better than ever now, thanks guys!
  1. Interface not Compatible error
    By Tre-Cool in forum FlashScan V2
    Last Post: January 14th, 2010, 12:13 PM
  2. Error V2 not compatible?
    By 1SlowHoe in forum FlashScan V2
    Last Post: May 23rd, 2008, 02:40 AM
  3. V2 is not compatible w/ V7.4.2?
    By pkincy in forum General (Petrol, Gas, Ethanol)
    Last Post: May 14th, 2007, 05:02 PM
  4. Error message: The Flashscan V2 interface is not compatible with this version of EFIL
    By Round Rock TJ in forum General (Petrol, Gas, Ethanol)
    Last Post: May 7th, 2007, 04:45 AM
  5. Is Live compatible with Vista?
    By Redline Motorsports in forum General (Petrol, Gas, Ethanol)
    Last Post: February 22nd, 2007, 02:12 AM
