Results 1 to 3 of 3
Thread: Aircon on now stalling
    Oct 2006
    Default Aircon on now stalling
    Now the summer temps are back I need to address an old issue that has been asked a few times but never solved.
    When coming to a stop with the aircon on my engine will stall.The only added air tables that I can find are B4301 & B4302 fan iac correction. Are these the only tables we can use to sort this issue or am I looking at this the wrong way.
    For instance is there hidden tables related to airflow we need to address in a different way.
    Car is a cammed M6 with 25% udp.
    The Tremor at AIR
    Lifetime Member macca_779's Avatar
    Jan 2007
    I've had similar issues in the past with A/C doing this. With mine it wasn't always stalling but what it would do is dip low and often hunt a couple of times before settling. With the fan tables you mention. I've only ever found them useful for the initial tip in activation of A/C. Almost like they prepare the engine for the extra load but don't really do anything while its already there.
    What I have done to fix it in cammed cars is just revise Follower so it decays quick initially then via an increasing multiplier value at 1200rpm and below in B4316 cause it to hang for approx .3sec before dropping to an 850rpm idle.
    Its also possible that you need more cracker air. I try and keep mine to a minimum but what I have now is approx .15 added when braking and approaching near stationary speeds.
    My advice is to just log follower and cracker air to make sure its actually being applied for when you need it. Make sure its behaving how you want during stationary revs for the follower side of things and from there move on to cracker settings. Just remember that decay rates are quite small in value so just work in percentages when trimming them.
    Oct 2006
    Thanks macca 779 I will give this a go.
    The Tremor at AIR
  1. Unregonized PCM after in stalling updates
    By esco35m in forum RoadRunner Real-Time PCM Emulator
    Last Post: January 31st, 2009, 09:04 PM
  2. Stalling issue... almost everywhere
    By lastcall190 in forum Gen III V8 Specific
    Last Post: November 21st, 2008, 08:33 AM
  3. IAC Steps and near stalling....
    By LS1_Dragster in forum Gen III V8 Specific
    Last Post: June 10th, 2008, 01:06 PM
  4. Intermittent Stalling...
    By ArKay99 in forum General (Petrol, Gas, Ethanol)
    Last Post: September 27th, 2007, 01:59 PM
  5. how do I prevent stalling when reving
    By tgeers in forum General
    Last Post: April 9th, 2006, 02:27 AM
