What map sensors do most people use. I am in darkest Africa and the only thing thats readily available is the std GM type.
Will this work or do I have to get the Saturn one?
\"You Can Never Have Enough Horsepower\"
The Saturn or Cobalt SS sensor fits the new, smaller connector without an adapter. If you have the larger size sensor, you can get a harness adapter from www.ls1speed.com , or simply chop a large GM MAP sensor plug off just about anything at the junkyard and splice it in.
World's First Twin Screw Pontiac GTO
2004 GTO. Blown H/C 408, stage 3 keyboard, billet tires
2017 Chevy SS with dead hooker is spacious trunk
2014 Chevy Cruze. MPG queen with my balls in spacious glove compartment.
www.aussiemotive.com
Ok So it does work.
I have a pile of GM harnesses so getting a plug is the easy part. Thanks
Fitting a Magnacharger to a 2005 ute and want to go mafless.
