Oh oh, I should checked the DL page before I asked. I see it now.
Scratch that request.Thanks
I see posts referring to a new version, but it is hard to tell if that is 7.5.4 Build 66 or not.
2002 WS6, All-Lunati 383 Strok'r @11:1, Cartek Heads, Keith/Ross Racing Custom Cam, Victor Jr., 492whp 457wtq,
Cartek Clutch, 9" Moser w/4.11's, 35 spline Detroit Locker, QA1's, NX, BMR, Tuned w/ EFILive V2 Black Box Logging
Check Out My Latest Tune File: HERE
What is new in this package?
EFILive V7.5.5 (Build 70)
New Features
· Added support for new E38, E67, T42 and T43 operating systems.
· Added option to manually enter your own calibration verification numbers (CVN) for E40, E38, E67, T42 and T43 controllers. Workshops can now uniquely identify their own calibrations. This feature is only available to customers with a stream license for the target controller(s). It is available via the new [CVN] tab page on the calibration details window in the EFILive Tuning Tool software.
· FlashScan V1 Workshop cables and FlashScan V2 cables with matching stream licenses can now transparently re-flash controllers with missing serial numbers.
· Changed the following PIDs to use PSI instead of inHg:
- GM.EGRVAC
- GM.BARO
- GM.MANVAC
-GM.MAPBOOST_DMA
· Script generation has been changed so that if an entire table is to be added to the script the coordinates are generated as “.” Instead of literal min/max column/row values. That prevents scripts failing when run against tunes with different axis labels.
· A command line parameter of – (a single minus sign) will cause EFILive Tune Tool software to not attempt to load any pre-existing *.tun files. To use this option, you need to create a shortcut to the EFILive Tuning Tool software with a target of: EFIlive_Tune.exe –. (I.e. EFILive_Tune.exe<space><minus sign>)
· Launch control spark retard PIDs added for Lingenfelter LNC-002 launch controller. PIDs are called:
- CALC.LNC002_1
- CALC.LNC002_2
· Added F.A.S.T. wide band O2 analog PIDs. PIDs are called:
- CALC.AFR_F1
- CALC.BEN_F1
- CALC.AFR_F2
- CALC.BEN_F2
- CALC.BEN_F1_B
- CALC.BEN_F2_B
- CALC.BEN_F1_E38
- CALC.BEN_F2_E38
· Added two new SAE PIDs called:
- SAE.FUELTYPE: Fuel type
- SAE.E85R: Ethanol Fuel Percentage
EFILive_Explorer V8.1.2 (Build 40)
New Features
· None.
Bug Fixes
· Fixed display refresh problem when swapping between AutoCal and FlashScan devices.
· Corrected error message when no firmware file was selected and the [Program] button was clicked.
I Can't see any updates mentioned in threads or on download pages....is Build 70 restricted to a subset of users at the moment (no problem if it is, just concerned that I might have missed something).
Jim
Hi Jim,
It's on the new website: http://www.efilive.com/index.php?opt...=48&Itemid=124
How come the online update isnt picking this up?
Beta?
2014 VF SV LS3 Maloo.
Thanks Joe,
Didn't know there was a new website...hard to keep up.
Many thanks
Jim
It says I have to uninstall the previous version to get the versions on their webpage for the 17 Oct 08 update.
Ugh, screw that.
Are they ever going to add more features for us LS1 guys? EG fix the missing INJFLOW and stand alone flashing.
Looks like pretty much all the new stuff has been for late model guys.
