working on a friends car- "346, AFR 205s milled to 62cc w/8019 springs, Pat. G cam (231/235 LSL), Fast 90, NW 90 TB, 42 lb racetronix, Kooks 1.75" LT's, Kooks Y w/cats, Yank PT4000"
On a cold start the car wont start unless you give it a decent amount of throttle then hold it for a few seconds and the car will sometimes keep it self running. I got the ve table all dialed in, as it starts warm just fine. It does smell a tad rich at times when trying to cold start.
I have tried to add a little, a ton, everything to the desired airflow table. No success. I tried changing the desired idle speed to like 2000 when cold and no matter what i put it only idles around 1000.
It is hard to get a good log since it is a cranking issue, and for me to get it started i have to hit the gas.
from what i have seen:
Idle spark is around 28
KPA- 55 (i thought maybe a tad high, but no vaccum leaks found)
IAC- I have seen sit at 310 when cold. It settles around 50 when hot. The throttle is set open about 3 degrees and tps values reset.
I attached the Tune file. I went threw what i thought was everything and tried changing everything to a know good idle on a similar setup, but with no luck.
