Results 1 to 10 of 12
Thread: 02 TA idle problem
    Jul 2008
    Default 02 TA idle problem
    all i have done to my car is 92 mm intake/TB, headers, 2400 stall converter, and stage 2 trans. everything else is stock the tune is pretty much stock as well. i have this problem when im slowing down sometimes where the car just goes dead, the idle slows down like normal and then goes under 500 rpm and quits sometimes it will revive it self sometimes it wont. so can anyone take a look at my tune and tell me if maybe there is somthing i didnt do for the stall converter. and any other pointers would be awesome. thanks in advance.
    Jul 2008
    uhhh.. anyone??
    Jul 2008
    I would approach your idle problem with the same methods used in tuning a car with a bigger cam. Obviously, your airflow requirements must have changed.
    There are some great tips in the 'idle tuning' tutorial found in the 'stickies', but here is a synopsis.
    1). Are you now overly rich upon startup? (stock VE).
    2). Double-check your desired airflow. Might need more.
    3). Utilize some of the tutorial tips concerning the learned airflow corrections.
    You might just try adding some air via the desired airflow table.
    Aug 2007
    In looking at your tune... who messed up your Throttle Cracker and Follower tables? I would start by trying the stock tables then make slight adjustments from there based on idle down and deceleration behavior. Get those tables close, then go through the RAFIG or RAFIN process as well as get your VE table tuned properly. Especially around the idle area in the table.
    2002 WS6, All-Lunati 383 Strok'r @11:1, Cartek Heads, Keith/Ross Racing Custom Cam, Victor Jr., 492whp 457wtq,
    Cartek Clutch, 9" Moser w/4.11's, 35 spline Detroit Locker, QA1's, NX, BMR, Tuned w/ EFILive V2 Black Box Logging
    Check Out My Latest Tune File: HERE
    Jul 2008
    i didnt mess with any of that stuff but ill look into it thanks
    Jul 2008
    i just looked at all the throttle cracker and follower tables and they are the same as the tune that the car came with when i got it. if that is wrong can someone send me a tune to know what its supposed to look like. thanks
    Lifetime Member Doc's Avatar
    Oct 2005
    Did you use the FAST valley cover button head bolts? Did you employ the stock torque pattern and spec for the intake? Is the MAP sensor fitted secure?
    www.efialchemy.com
    www.greatamericancarwar.com
    Jul 2008
    As outlined in the idle tuning tutorial, in addition to airflow adjustments, there are several tips concerning spark. In addition to the idle spark underspeed and overspeed tables, I have made the timing at rpms (400rpm & 0) higher than the idle rpms ( base spark). If it is a spark problem related to idle, as your rpm's drop and your spark increases it prevents spark from dropping further.
    You could always P.M. SSpdDmon. He might tell you to apply the idle tutorial tips first, but either he or someone else might catch something else in your tune that is causing you problems. Other than a vacuum leak, those are my suggestions.
    Aug 2007
    Ditto. Weatherman has excellent advice. You can PM SspDmon. He also wrote some excellent articles on idle tuning. I would use his advice, but start from using stock tables. Not a stock tune!! Use your tune, just replace your cracker and follower tables with the stock ones. Stock tunes can be found here:
    http://www.holdencrazy.com/EFILive/stockTunes.php
    SspDmons article can be found here:
    http://forum.efilive.com/showthread.php?t=4661
    Is your car cammed? If you want to see my tune, let me know. Nothing about my motor is stock except the block... but it idles great, and never stalls. Keep us posted how it goes.
    Lastly, you also need to get that Desired Airflow at Idle set properly. Or at least close. This thread outlines how to do it. Thanks to SspDmon yet again.
    http://forum.efilive.com/showthread....=RAFIG+process
    Jul 2008
    ok so i have 4 different tunes open and im looking at all the cracker and follower tables. the automatics are different from the manuals. so far i havent found anything different from the stock settings to my tune for the automatic cars. my head is starting to spin a little bit. im pretty new to this still im looking into all the idle tuning thanks for the help and opinions
  1. idle problem
    By kostelacd69 in forum Custom Operating Systems
    Last Post: July 14th, 2009, 10:05 AM
  2. idle problem
    By kostelacd69 in forum General (Petrol, Gas, Ethanol)
    Last Post: April 13th, 2009, 06:21 AM
  3. Why can't I fix my idle problem?
    By sdhager in forum General (Petrol, Gas, Ethanol)
    Last Post: December 20th, 2008, 01:21 PM
  4. Idle problem
    By 12sec.5.3 in forum General (Petrol, Gas, Ethanol)
    Last Post: March 27th, 2007, 12:34 PM
  5. Very lean at idle RPM/MAP problem
    By jnorris in forum General (Petrol, Gas, Ethanol)
    Last Post: February 17th, 2006, 10:29 AM
