Results 1 to 4 of 4
Thread: V1 to V2 upgrade...
    Oct 2008
    Default V1 to V2 upgrade...
    I have recently purchased a V1 used... What would be a way to tell if this version has been upgraded to a V2 before I bought it? In other words I am making sure I can add licenses and tune additional vehicles...
    Also, how do I know whether or not the 97-98 unlimited stream has been activated on this version?
    Thanks in advance...
    Michael
    Quote Originally Posted by B8SMAN View Post
    Michael
    Send the serial number to me paul@efilive.com and I can tell you if it has been upgraded.
    The 97-98 stream is unlimited on all V1's by default. You should not be asked to license a 97-98 PCM when you try to flash it
    If you have attempted to flash a 97-98 and were asked to license the PCM, then don't - let me know and I will investigate if there is a problem.
    Oct 2008
    well I'm having trouble pulling the factory tune out of the car... it gets about half way through and then stops... at the time it stops all the led's on the interface turn off... I have let it sit for up to 8 minutes before I manually stop it... the scanner works fine, connects and will pull codes, however, the real time doesn't seem to work...
    I will email you the serial number and reference this post...
    Thanks,
    Michael
    Oct 2008
    Email sent...
  1. 99 Z28, to upgrade OS or not?
    By N0DIH in forum Gen III V8 Specific
    Last Post: October 16th, 2008, 01:56 PM
  2. Upgrade E-38 OS?
    By Bruce Melton in forum E37, E38 & E67 PFI ECM's
    Last Post: June 16th, 2008, 09:45 AM
  3. Upgrade 02 help?
    Last Post: April 6th, 2007, 06:46 AM
  4. upgrade OS??
    By ws6togo in forum Custom Operating Systems
    Last Post: January 10th, 2006, 07:10 PM
  5. No ETC after upgrade
    By curtbriggs in forum General (Petrol, Gas, Ethanol)
    Last Post: October 14th, 2005, 08:35 AM
