Results 1 to 10 of 11
Thread: New PID for Lingenfelter launch controller...
    Oct 2007
    Default New PID for Lingenfelter launch controller...
    ok so i select ad.2 pid and then the lingenfelter launch controller pid... what does the pid log???
    thanks....
    01 Z06, 4L60E CONVERSION, L92/L76 TOP END, 72# LS3 INJECTORS (THANKS FIC), DRY NITROUS, COS5
    Oct 2007
    anyone???
    Jul 2007
    Quote Originally Posted by WHYTRYZ06 View Post
    thanks....
    should be the voltage coming on ad2. You might need a calc pid to convert it to useful data.
    07 Silverado DMax Classic
    02 Z06 LS3 416, 805rwhp, TFS245, Wiseco, Callies Crank/Rods, Iskendarian Lifters, Crower Rockers, FAST102/90, ATI Damper, 1-7/8 Kook's LT, QkTime Shield,Tolle-Fab 8pt
    Old Engine: 1/4mile = 9.6/146 New Engine:?
    EFI Live Tune/Scan v7.5.27, EFI Live Scan and Tune v8.2.23, build 276, BootBlock 2.07.06, FirmWare 2.07.52, 512K RoadRunner (12.14.R), Innovate Serial LC2x2
    COS5/12212156 For 2002 Z06 Manual Vette
    Oct 2007
    whats the point in logging it??? the 2step i mean
    Lifetime Member Beer99C5's Avatar
    Jul 2006
    I am not familiar with two steps yet (other than making some panels with some)...
    Seems like it would be nice to know when it was active (compare rev limiting/timing to programmed values w/ active), I would think relay status inputs for the V2 would suffice for that as opposed to using an AD input?
    1999 C5 A-4 Convertible
    1 of 245 Nassua Blue 99 Vert's, Blackwing, LS6 Intake, 42 # Injectors, Two Stage Nitrous System- Dry and a Wet Plate, EFI Live Scan/Tune V2, 1999 PCM with 2002 COS 5 OS Custom Nitrous Panel.
    Maine USA
    Used if you have one of these boxes -
    http://www.lingenfelter.com/store/l460095297.html
    Jul 2006
    I found that ok, and read the instructions before I posted, the question still stands, what does the PID tell you? Is it a AD input or is it more a relay status (on off)...
    Maine USA
    Jul 2007
    From the Lingenfelter LNC-002 page, the following is noted...
    Analog voltage output wire for sending timing retard information to data acquisition systems EFILive, HPTuners, DashDAQ, etc.
    Then in EFILive the Lingenfelter Launch Control Spark Retard AD-2 PID is described as...
    Expression:
    Degrees = {EXT.AD2}*5.0
    So I'd think that the Lingenfelter controller will output an analogue voltage signal that is a direct representation of the 0' to 15' of spark retard that it is controlling. So it's not a "relay on / off" signal, it'll be a varying voltage, a little like a WB signal.
    Now, the Lingenfelter page does not note what the analogue signal limits are, but the EFI PID indicates that the resultant data is {EXT.AD2}*5.0. The Lingenfelter will retard up to 15' so I'd say the analogue signal is 0-3V, 0v = 0 retard, and 3V=15' retard.
    Is this what you are after?
    Simon
    Last edited by swingtan; October 27th, 2008 at 03:41 PM. Reason: Fixed my contradicting statements.....
    Jul 2006
    Yep, Thats pretty neat
    Maine USA
    Default Lingenfelter timing controller/launch controller voltage output PID
    Simon,
    That is the correct description of the signal. The LNC-002 timing controller/launch controller outputs a 0 to 3 volt DC signal proportional to 0 to 15 degrees of ignition timing retard with 0 volts being 0 degrees and 3 volts being 15 degrees of retard. Because our box modifies the timing after the ECM/PCM, the ECM/PCM doesn't know what the actual timing being delivered is so we provide the analog voltage output so that you can record and calculate what the actual timing is when our device is retarding the timing (ECM/PCM delivered timing less the amount of retard indicated by the analog output).
    Quote Originally Posted by swingtan View Post
    Simon
    Jason Haines, Project Director
    Lingenfelter Performance Engineering
    jhaines@lingenfelter.com
    260-724-2552
  1. Replies: 25
    Last Post: May 28th, 2010, 01:12 PM
  2. Torque up and launch problems
    By chipper5564 in forum Gen IV V8 Specific
    Last Post: January 4th, 2010, 10:51 AM
  3. Possible to install Launch Control on Pre-10 Cars?
    By Highlander in forum E37, E38 & E67 PFI ECM's
    Last Post: December 18th, 2009, 05:51 AM
  4. Launch tuning
    By DrX in forum General (Petrol, Gas, Ethanol)
    Last Post: October 11th, 2009, 08:26 AM
  5. No KR, but timing pulled on launch
    By efizjb in forum Gen III V8 Specific
    Last Post: February 6th, 2008, 03:25 PM
