I just upgraded to V7.3, Flashed in the custom O.S. 02020003 WITH 12221588 CALIBRATIION(2002 SS CAMARO).
I went through the entire custom 2/3 bar tutorial.
My question is the last section about open and semi open loop. I want to tune the motor using actual AFR with my wideband and then have it stay at those settings. Do I always need a wide band hooked up permanantly to run in open loop? I want to drive the car tomorrow and want to know the best way to set this up? It is not an everyday driver. Anyone?
Also My program still shows a high and low octane spark table. Is it supposed to? What tables do I modify with lower timing for my 3 bar setup?
