Page 1 of 3 123 LastLast
Results 1 to 10 of 27
Thread: serial port cable that goes to v2
    Mar 2007
    Default serial port cable that goes to v2
    does any one have a diagarm to make the serial cable for the v2 with the 9 pin serial port to the 6 pin phone jack looking connector. hope i am explaining correctly.thanks
    You should have got one with your V2. It would be easier (and cheaper) to order one through one of our resellers, we don't try to make money on spare cables, it more to cover costs and provide a replacement service.
    Need official EFILive help, please go here.
    For tuning support please post your questions on this forum (or other auto forums).
    Sorry if I don't respond to your PM, don't take it personal.
    Cable wiring diagram (for LC-1): FlashScan-to-LC-1-Serial-Cable-Diagram
    Your V2 came with a DB9 serial cable...
    Your wideband came with a DB9 serial cable...
    You need a null-modem adapter (orange item in pic below)... [it has to be a null-modem adapter and not just a gender bender].
    To enable serial AFR in the V2, see here: Tutorial-FlashScan-V2-Serial-Wideband-Logging
    You also have to remember to plug the null terminator plug (blank 2.5mm stereo plug) into the LC-1's SERIAL IN cable.
    This is the null-modem adapter: http://www.sfcable.com/cable/p/30D1-C1-S.html <-- less than $5 shipped
    Mar 2007
    i cannot find my db9 cable but i bought a 6 pin jack and a DB9 female to RJ11. will this work?
    Mar 2007
    i found my cable. now can i connect it with a null modem adapter and cut the end off a serial cable and connect to the fjo wires?
    Nov 2006
    ____RJ12______
    1 = Tx Data
    2 = Rx Data
    5 = Ground
    If you can identify Tx, Rx, Gnd, then you wire them as shown in post #6 and you don't need the null-modem adapter.
    If it doesn't work, swap Tx and Rx.
    Mar 2007
    thx i will try tommorrow
    The AFM1500 pins are as noted;
    pin #1= Rx
    pin #2=Tx
    pin #3=Grnd
    According to the AFM1500 manual;
    DB9 Female (to PC)
    Terminal Number
    #2 (Rx) to pin #1 of module (male)
    #3 (Tx) to pin #2 of module (male)
    #5 (Gnd) to pin #6 of module (male)
    I assume "to module" is the AFM1500 box and the "to PC" is the feed heading to the V2??
    Trying to reason through the null modem conversion. Ughh!
    Howard
    www.redline-motorsports.net
    1-954-703-5560
    2006 ZO6 895/866 with APS TT
    2011 HTR-850R Camaro
    Nov 2006
    Are you trying to bypass a Null Modem?
    RS232 serial cables pinout
    LC-1 WBO2
  1. Flashscan to LM-2 Serial Cable
    By TAQuickness in forum FlashScan V2 BB Logging
    Last Post: May 2nd, 2016, 09:36 AM
  2. FlashScan to LC-1 Serial Cable Diagram
    By Blacky in forum FlashScan V2 BB Logging
    Last Post: November 26th, 2009, 06:50 AM
  3. Tried making own Serial Wideband Cable, HELP!!
    By edwardzracing in forum FlashScan V2
    Last Post: March 18th, 2009, 03:54 AM
  4. fjo serial cable questions..please help
    By articSS in forum Black Box Logging
    Last Post: October 28th, 2008, 02:05 PM
  5. Calibrating AD port
    By stigmundfreud in forum Black Box Logging
    Last Post: March 30th, 2008, 11:21 PM
