Page 3 of 3 FirstFirst 123
Results 21 to 27 of 27
Thread: serial port cable that goes to v2
  1. #21
    Howard,
    Try this:
    - connect the AFM to your PC's serial port using the null-modem adapter,
    - go Start->All Programs->Accessories->Communications->Hyper Terminal,
    - enter any name (AFM),
    - click OK,
    - enter any area code and phone number (111 2223333),
    - set Connect Using to COM1 (or whatever your PC's COM port is),
    - click OK,
    - set 38400 baud, 8 Data Bits, Parity None, 1 Stop bit, Flow Control None (from the AFM manual),
    - click OK,
    - now you should be in the terminal window...
    In the terminal window you should see stuff being printed... if not then remove the null-modem adapter.
    If it still doesn't print, shutdown HyperTerm and restart it, this time specify the other COM port (e.g. COM3), and try again with and without the null-modem adapter.
    I assume this is to see if the two devices are at least communicating with or without the null modem? Once we see communication from the AFM to the PC we can then hook up to the V2 via the RJ12.
    Hopefully after that we can get the trace done and move on!
    I'll try this tomorrow if its this straight up.
    Thanks Joe
    www.redline-motorsports.net
    1-954-703-5560
    2006 ZO6 895/866 with APS TT
    2011 HTR-850R Camaro
  2. #22
    BTW: Howard @ Redline Motorsports did get serial AFR/Lambda working with his AFM1500 wideband:
    showthread.php?12641-Add-the-ECM-AFM1500-to-the-serial-WB-list!
  3. #23
  4. #24
    Lifetime Member Tinbender59's Avatar
    Jun 2010
    Default My serial cable
    Here is a quickie paint of my LC-2 to V2 serial cable connections. port 1 in Molex to port 1 in RJ12 ect, ect hope this helps
    SEE ALSO
    https://forum.efilive.com/showthread...449#post209449
ID:	17333   Click image for larger version.
Name:	RJ11 VS RJ12.jpg
    Last edited by joecar; August 19th, 2014 at 12:56 PM. Reason: corrected to say LC-2
  5. #25
    Tinbender, you mean LC-2...?
  6. #26
    Jun 2010
    Yes. Yes. I R Smart!!! Lol
  7. #27
    Ok, I corrected it.
  1. Flashscan to LM-2 Serial Cable
    By TAQuickness in forum FlashScan V2 BB Logging
    Last Post: May 2nd, 2016, 10:36 AM
  2. FlashScan to LC-1 Serial Cable Diagram
    Last Post: November 26th, 2009, 07:50 AM
  3. Tried making own Serial Wideband Cable, HELP!!
    By edwardzracing in forum FlashScan V2
    Last Post: March 18th, 2009, 04:54 AM
  4. fjo serial cable questions..please help
    By articSS in forum Black Box Logging
    Last Post: October 28th, 2008, 03:05 PM
  5. Calibrating AD port
    By stigmundfreud in forum Black Box Logging
    Last Post: March 31st, 2008, 12:21 AM
