one of our projects has a case relearn dtc. i cant get the scan tool to perform this funtion. i get a dvt fault active error. i have researched and all of the faults are not present and the engine is at running temp. the setup is an e38 ecm with a fast harness and gm tcm with an ls3. we can give the system a brake signal but apperantly a parking brake signal is needed. we dont have a bcm. the bcm would get this signal? anyway around this? i have updated to all of the latest versions
