Results 1 to 9 of 9
Thread: Can't log?
    Oct 2007
    Default Can't log?
    Went to log a run for the first time after 7.5.4.65 and keep getting error code $11 not supported. Probably something I didn't do right!! Thanks in advance for your help. RR
    What vehicle/ECM...?
    Oct 2007
    Duh!! 06 LBZ I'm still looking for my error. I still have the old 7 version so I see if it run that in the morn. Thanks Joe RR
    Sep 2007
    any fix? I just got this...
    Did you update to Build 84 software...?
    And you have to update your FlashScan V2 bootblock/firmware.
    Sep 2007
    Hi Joecar!
    Yes, I'm on build 84 software. I went to EFILive explorer and it then updated my bootblock to the 'latest' available it stated.
    I went back out to the truck, tried again, and NOTHING. I then changed the logging mode to dynamic and still same error.
    Here's the list it gave me from the scan n tune error:
    [quote=scan n tune]
    Error report generated by EFILive at 15:04:49 on May 12, 2009
    Error code: ERR_RESPONSE/5
    Response $11: "Mode Not Supported".
    EFILive Version: 7.5.5 (Build 84)
    Platform: Windows XP
    Version: 5.1 (build 2600)
    Processor type: Pentium 1995MHz
    Directories
    Temporary Cache: C:\Documents and Settings\Jason\My Documents\EFILive\V7.5\Temporary cache
    Logged Data: C:\Documents and Settings\Jason\My Documents\EFILive\V7.5\Logged data
    Customers: C:\Documents and Settings\Jason\My Documents\EFILive\V7.5\Customers
    Configuration: C:\Program Files\EFILive\V7.5\Configuration
    Exported Data: C:\Documents and Settings\Jason\My Documents\EFILive\V7.5\Exported data
    Images: C:\Documents and Settings\Jason\My Documents\EFILive\V7.5\Images
    Sounds: C:\Documents and Settings\Jason\My Documents\EFILive\V7.5\Sounds
    Maps: C:\Documents and Settings\Jason\My Documents\EFILive\V7.5\Maps
    Pids: C:\Documents and Settings\Jason\My Documents\EFILive\V7.5\PIDs
    Virtual Dash: C:\Documents and Settings\Jason\My Documents\EFILive\V7.5\VDash
    Print Reports: C:\Documents and Settings\Jason\My Documents\EFILive\V7.5\Print reports
    Bug Reports: C:\Documents and Settings\Jason\My Documents\EFILive\V7.5\Bug reports
    Connected: No
    Com port: 0
    Com setup: EFILive FlashScan V2.5: USB
    Requested baud rate: 115200
    Cable id: 7
    Cable code: FlashScan V2
    Cable desc: EFILive FlashScan V2
    Cable version: 2.6.6
    Cable Firmware date: 20081214
    Cable model: FSV2
    Cable Serial number: 003635578445
    Protocols: 0
    Protocol list:
    Auto connect: No
    Scan OBDII info: No
    Error retries: 1
    Retry delay: 10
    Message throttle: 0
    Most recently used VIN: 1GTJK33D07Fxxxxxx (Note: 1)
    PCM information
    Hardware Number: Unknown
    Calibration ID: 12606127
    Serial Number: 86J628603950
    Operating System: 12632483
    Engine Operation: 12632640
    Engine Diagnostics: 12632655
    Engine: 12632720
    Not used: 12632666
    Fuel System: 12632666
    System: 12632677
    Speedometer: 12632700
    Boot Block: YNAY
    Stream-Slow scan mode: Supported
    Stream-Fast scan mode: Supported
    Maximum dynamic packets: 16
    Detected modules:
    $11="Engine Control Module (ECM)"
    $18="Transmission Control Module (TCM)"
    Selected parameters:
    CALC.POWER_RW=1,4308
    GM.BOOST2_DMA=1,4440
    GM.DESTCBOST=1,4478
    GM.EGR=1,4503
    GM.EGRCOM=1,4504
    GM.ENGOILP=1,4517
    GM.ENGTRQREF_DMA=1,4519
    GM.FRPCOM=1,4599
    GM.FRPDES=1,4601
    GM.FUELRCALC=1,4614
    GM.MAIN1Q_DMA=1,4736
    GM.MAIN1T_DMA=1,4737
    GM.MNINJTIM=1,4782
    GM.PILOT1Q_DMA=1,4851
    GM.TCVDES=1,4999
    GM.TCVLRNC=1,5000
    GM.TCVLRNO=1,5001
    GM.TCVPOS=1,5002
    GM.TP=1,5027
    SAE.AAT=1,5091
    SAE.BARO=1,5098
    SAE.ECT=1,5113
    SAE.EGR_PCT=1,5115
    SAE.FRP_C=1,5123
    SAE.IAT=1,5126
    SAE.LOAD_PCT=1,5128
    SAE.RPM=1,5152
    SAE.TAC_PCT=1,5158
    SAE.TP=1,5159
    SAE.VPWR=1,5167
    SAE.VSS=1,5168
    Sep 2007
    If you need ALL of it I'll email it to someone - the forum won't let me post it (as it's too long)
    This is on a 07 Dmax LBZ
    The error will be that one of the PIDs in that list is not supported.
    Remove one PID at a time until the error goes away which will indicate that the PID you just removed was responsible for the error.
    Or send me the entire file (paul@efilive.com) and I can tell you which one it is.
    Sep 2007
    Thanks Paul!!
    You got it right on... It didn't like these:
    GM.TRQ_fact... engine power limiting factor
    GM.PILOT1Q_DMA Pilot injection #1 Fuel Flow Mm3
    SAE.AAT Ambient Air Temperature
    I deselected them and all is well!!
