Results 1 to 8 of 8
Thread: Error code
    Sep 2007
    Default Error code
    when using v2 in stand alone mode, trying to erase DTC's I get this error code
    $0281 anybody know what it is
    According to the error files in the V8 folder, it means "No data received". Cant help you out on how to fix it, but what firmware and boot block are you running?
    Sep 2007
    V8.1 Bootblock v2_05_08 Firmware v2_05_20
    What vehicle/PCM...?
    When you press Ctrl+Ok, do you see any VPW/CAN indication in the lower right corner of FlashScan's screen?
    If you do then FlashScan is communicating with the vehicle ok.
    If not then FlashScan cannot communicate with the vehicle.
    Try updating to the latest boot block (V2.06.02) and firmware (V2.06.04)
    Sep 2007
    LLY 05
    I can record / flash and do other things, I just get this when I try and erase the DTC's
    Sep 2007
    I can Record, scan, flash, gather DTC's I just can't erase, to erase I have been reflashing to get rid of them. I removed the EGR completly and keep getting 1404 EGR closed, No Mil, no report
    Quote Originally Posted by Toired Old Man View Post
    There was a problem that caused DTC reading to fail when reading LBZ/LMM - if your LLY is a late 2006 model with the Bosch controller then the problem will affect your LLY as well.
    Try updating to the latest boot block (V2.06.02) and firmware (V2.06.04).
    You can get the updates by downloading and installing EFILive V8.1.2. Then when you run EFILive Explorer you will be notified that you need to update your boot block and firmware.
    The V8.1.2 download is available here:
    http://www.efilive.com/index.php?opt...=48&Itemid=124
  1. error code 11?
    By dynarex in forum General (Diesel)
    Last Post: April 23rd, 2007, 09:07 AM
  2. Error code: ERR_NOCABLE/31
    By Chalky in forum General
    Last Post: May 16th, 2006, 08:40 AM
  3. error code ERRNOINIT/121
    By raptor in forum EFILive V6
    Last Post: November 14th, 2005, 07:51 PM
