Page 2 of 9 FirstFirst 1234 ... LastLast
Results 11 to 20 of 86
Thread: LBZ equivalent of B0751/B0752?
    Jan 2008
    Yeah that too
    hahaha
    May 2007
    Quote Originally Posted by bballer182 View Post
    Any chance those tables could be "activated"? Been playing with smoke control and mileage since the DSP release makes it easier to do. rather than flashing a new tune every time you wan to make a change just load up 5 instead.
    Sure I can look in to it after SEMA, too much to get done before then.
    Have you guys had a chance to look into this?
    '07 LBZ Classic, BW S464 Turbo, EGR deleted, 3" IC piping, Trans-go, ATS 5-star converter, stock clutches
    Feb 2007
    Hey Ross, any update on this? If I can help in any way, please let me know what I can do. Thanks.
    smoke control with dpf deletes continues to be a huge issue. Would really like to find out how GM does it, the answer must exist.
    Custom Tuning Services
    Feb 2007
    The LMMs have a table that is supposed to be for smoke control. I posted the table number in this thread; it uses lambda. I don't have trouble with smoke except for with bigger injectors. I could probably fix it in the pulse table, but that would screw up a lot more than it would fix. I'd really like to limit mm3 with MAF and RPM. There has to be a table in there somewhere.
    Thanks Josh.
    Joel, have you (or anyone else) used B0795 to effect maf fuel limiting? Did it work as desired?
    IIRC, I was not able to accomplish anything with it.
    Feb 2007
    I've never tried it myself. Like I said, I haven't had any problems with excess smoke on an LMM. Here's an LMM on a dyno that put down almost 480 HP. The smoke you see is because of the right outer dual rubbing on the guard at the edge of the roller.
    http://www.youtube.com/watch?v=YIMjrsuDDWU
    bet a bag of donuts that is dpf equipped. It works great to reduce, eliminate, smoke.
  9. #19
    Quote Originally Posted by JoshH View Post
    That would be B0795.
  10. #20
    Jan 2008
    So, haven't heard anything yet. Any chance it might happen?
  1. B3601 equivalent in E38
    By Chalky in forum E37, E38 & E67 PFI ECM's
    Last Post: September 7th, 2009, 11:02 PM
  2. B0751 MAF limited fuel quantity
    By killerbee in forum Duramax LLY
    Last Post: September 18th, 2006, 09:47 AM
