Originally Posted by
nitrorocket
I know how to copy, I just was basibally wondering what tables affect the tune. After comparing, It seems most all tables are the same. I am now using my 2000 dyno'd tune main ve chart.
The problem I had was after I swapped to the custom O.S. and stock 2002 tune. The car would not idle at all. After messing around with the IAC it got better but would surge real bad.
The numbers on my dyno'd Main VE chart were about 10% different. I will try that tomorrow to see if that will make it idle again. Could it be because I have the idle STFT's disabled? The O.S. tutorial said to, but I don't know why it has the idling problem. I will find out tomorrow I guess.
