Results 1 to 9 of 9
Thread: Speed density run.
    Jul 2007
    Default Speed density run.
    Howdy Guys, got the 2.5' pulley and place it on the whipple ...did a run with the speed density tune and I notive knock and seems on the tables that the tahoe is Starving from Fuel, Header Glow orange at nite ..*Yikes*
    I see 75% duty cycle on the 39lb injectors, and I notice that the A/F varies..
    2 bar map Gives me a 172kpA max I think.
    Any opinions? suggestions? Upgrade Injectors, timing??
    Dont want to keep my mouth close and blow the engine, I Rather Ask
    Gilbert
    Oct 2006
    Quote Originally Posted by nissmo View Post
    Gilbert
    First thing I would do is invest in a wideband o2 sensor & follow the autoVE procedure. This will help get your fuelling in line. Your boost VE table for starters is definately incorrect as it should increase with map, not be a flat table like yours.(unless you are using a step up regulator for fuel pressure.)
    It might be a good idea to fully list your mods.
    Cheers Mick
    The Tremor at AIR
    Jul 2007
    Quote Originally Posted by 5.7ute View Post
    Cheers Mick
    I do Have a WB mods are 2 bar map, 39lb injectors, 411 ecm,walbro 255.
    Oct 2006
    No worries. Wideband data is not in your log so your actual AFR is just guesswork from the o2 sensor data.
    The Tremor at AIR
    Jul 2007
    Default wideband, speed density log
    Hope I did it Right this time.
    Gilbert,
    Both wideband AFR pids look flat...
    Also, look at IAT... it is going off the scale... something might be wrong with it.
    Gilbert,
    Does just 1 or 2 primary pipes glow, or do all of them glow...?
    Jul 2007
    Gilbert,
    Hey joe!
    well Very First time that I notice that I was Running on the sand dunes and the compleate exhaust was orange, including cats and Flow master, last nite since I did a Couple of runs Only the Left side sitting on the Vehicle and part of the Y pipe.
    Gilbert
    Did yall see the codes it was throwing?
    Diagnostic Trouble Codes
    P0112 "Intake Air Temperature (IAT) Sensor Circuit Low" ($10) "Powertrain Control Module (PCM)"
    P0341 "Camshaft Position (CMP) Sensor Performance Bank 1 Sensor A" ($10) "Powertrain Control Module (PCM)"
    P0102 "Mass Air Flow (MAF) Sensor Circuit Low" PHC ($10) "Powertrain Control Module (PCM)"
    P0112 "Intake Air Temperature (IAT) Sensor Circuit Low" PC ($10) "Powertrain Control Module (PCM)"
    P0341 "Camshaft Position (CMP) Sensor Performance Bank 1 Sensor A" PC ($10) "Powertrain Control Module (PCM)"
    P1112 "Intake Air Temperature (IAT) Sensor Circuit Intermittent Low Voltage" PH ($10) "Powertrain Control Module (PCM)"
    P1665 "Engine Oil Pressure Output Circuit" PHC ($10) "Powertrain Control Module (PCM)"
    History data
  1. Do I need the Speed Density COS?
    By MisterGuru in forum Custom Operating Systems
    Last Post: June 4th, 2009, 11:41 AM
  2. Speed Density
    By Yortt in forum Gen IV V8 Specific
    Last Post: December 1st, 2008, 01:11 PM
  3. speed density
    By mikesp1 in forum E37, E38 & E67 PFI ECM's
    Last Post: July 31st, 2007, 05:29 PM
  4. speed density
    Last Post: January 14th, 2006, 06:13 PM
  5. Speed density
    By Drake in forum Tutorials
    Last Post: February 22nd, 2005, 03:01 PM
