Results 1 to 6 of 6
Thread: Manvac pid
    Jun 2008
    Default Manvac pid
    I just updated to 7.5.5
    I want to keep manvac in inHg. Is there a way I can switch that back to inHg? All there is now is kPa and PSI.
    Am I left with just putting the older version back on?
    You may need to create a calculated pid in calc_pids.txt to display MANVAC in inHg.
    Is the pid in question GM.MANVAC...?
    Is your calc_pids.txt file the default one or have you edited it before...?
    If it's the original one, I can make you one later, I'll post it here.
    Jun 2008
    yes, GM.MANVAC
    default pid file.
    Thank you!
    Copy this file to either of (whichever one you have):
    My Documents\EFILive\V7.5\User Configuration
    My Documents\EFILive\V7\User Configuration
    Then open scantool:
    in PIDs tab, select both GM.MANVAC and CALC.MANVAC;
    in charts/gauges, available pids are:
    CALC.MANVAC.inHg
    CALC.MANVAC.psi
    CALC.MANVAC.kPa
    Jun 2008
    thanks a ton!
    I see what you did. Hopefully i can do the next one now!
    Jan 2007
    Everytime, I tried to measure something with an inch of mercury is just puddles up so I just switched to kPa. Also, I was running out of peoples' feet to cut off for measuring things with so I went with meter sticks.
  1. Gm.manvac
    By 1bar in forum General (Petrol, Gas, Ethanol)
    Last Post: June 9th, 2009, 05:08 PM
  2. What is the deference between {GM.MANVAC} and {SAE.MAP}?
    By odd boy in forum General (Petrol, Gas, Ethanol)
    Last Post: April 24th, 2008, 06:37 AM
  3. GM.MANVAC vs. SAE.MAP
    By Lennart in forum General (Petrol, Gas, Ethanol)
    Last Post: May 20th, 2007, 04:32 AM
