Results 1 to 7 of 7
Thread: Alerting Feature Request and Question...
    Aug 2007
    Exclamation Alerting Feature Request and Question...
    I was wondering if there is a way to use simple if/and/then logic with respect to the V2's audio and LED alerting functions.
    Meaning; instead of say sounding an audible alert and/or lighting an LED when a single threshold is met, can we make is contingent on multiple conditions?
    Example:
    Alert 1: KR > 0, then sound an alert. <--- the way it is today
    Alert 2: AFRWB01 > 12.80 and TP is >90% <--- mutiple condition alert
    Alert 3: AFRWB01 > 11.80 and S1 input sees +12v. <--- multiple condition with an input trigger
    With alert 3, I was thinking that I could wire the 12v+ side of my nitrous trigger relay to the V2, then I would be able to alert if I go lean or get knock, while spraying N2O.
    Thanks guys.
    2002 WS6, All-Lunati 383 Strok'r @11:1, Cartek Heads, Keith/Ross Racing Custom Cam, Victor Jr., 492whp 457wtq,
    Cartek Clutch, 9" Moser w/4.11's, 35 spline Detroit Locker, QA1's, NX, BMR, Tuned w/ EFILive V2 Black Box Logging
    Check Out My Latest Tune File: HERE
    Aug 2007
    I pm'd Paul, he will see this, he's on his way to SEMA at the moment.
    Aug 2007
    No worries. Thanks man!
    No, there is not currently a way to do that on V2.
    I am designing a way to support limited calculated PIDs on the V2. That may provide the functionality you need to configure a workable solution.
    May 2008
    Great to hear Paul!
    Thanks!
    Jan 2007
    You could do with a little simpler.
    Nitrous is only on at WOT. Program the WB for any AFR leaner than 11.50 = 1
    Alarm S1 on value =1
    Place relay in between WB and V2 that is open when not WOT and closed when WOT.
    Problem solved.
  1. New feature request / tell me how to
    By Doc in forum General
    Last Post: October 20th, 2009, 03:57 AM
  2. Feature request v2
    By ringram in forum General
    Last Post: July 9th, 2008, 04:44 PM
  3. Feature Request
    By Garry in forum General
    Last Post: August 29th, 2006, 01:34 AM
