Results 1 to 2 of 2
Thread: A6 Cal Shift Points Not Matching Actuals
    Dec 2007
    Default A6 Cal Shift Points Not Matching Actuals
    Anyone had any experience with calibrated shift points, not matching the actual logged shift points, on A6's or even A4's?
    This is with the speedo setup being correct on the ECM and TCM, with speedo indicating within 0.5%.
    Actual shift points, both up and down, and TCC engage points, are around 20% lower than the calibration.
    Yes it can be fixed by increasing calibrated shift points, but though there is maybe something else I am missing!
    cheers.
    Dec 2007
    Quote Originally Posted by gmh308 View Post
    cheers.
    At a guess, it would make logical sense, and be consistent given the variable loads these transmissions need to encounter, that there would be a torque based modifier to the alter shift patterns based on currently delivered engine torque. The mismatch I am experiencing is mainly light throttle (7-12% at the pedal), so maybe the strategy is to get to the highest gear as soon as possible under very light load.
    Anyone have any feedback on this? My Helms has not arrived yet. If that even covers that deeeeep.
  1. Little help with changing shift points
    By Tarkstoys in forum Allison 5 & 6 Speed
    Last Post: June 29th, 2009, 06:54 AM
  2. tuning shift points
    By hot-dog in forum Allison 5 & 6 Speed
    Last Post: February 28th, 2009, 08:03 PM
  3. shift points
    By rock04max in forum General
    Last Post: December 1st, 2008, 01:09 PM
  4. Help with 80E shift points
    Last Post: May 20th, 2008, 03:08 PM
  5. TCM shift points
    By lakingslayer in forum General (Diesel)
    Last Post: March 28th, 2007, 11:09 AM
