Results 1 to 10 of 14
Thread: pulling timing not in program
    Oct 2008
    Smile pulling timing not in program
    Hi guys i'm knew to efi live forum. i've got a 2001 4x4 p/u truck with a custom operating sys. 2 bar in it and have been working with it for a couple
    of month now when i'm not at work. It's been alot of work starting from scratch. the truck was a 496 allison to begin with and has evolved into a twin turbo 604 cu truck. my problem is that something in the programming is pulling 4-6 deg of timing that is not on any of the timing maps that i can tell.
    right now i have zeroed out all the timing maps for everything, the only timing maps i'm using are the high and low octain maps (which are the same) and the optomal timing map and the boost retard map. i log the truck and it seams that at wot it is pulling 4-6 degrees from somewhere. it's a drive by wire throttle and i'v increased the maps for them to not set a 1514 code. All the torque management is zeroed out and it has no traction control. i'm wondering if increasing the expected torque maps has some effect on the end timing tables? any input would be appreciated. thanks
    Feb 2008
    Is it pulling the timing once you go WOT and maintaining through the pull? Or does it start later on, maybe during a shift region/time?
    Can you post log and tune files.
    Oct 2008
    it pulls timing after the shift.i will attach the program and log file.
    May 2008
    It looked like the torque reduction was properly disabled, but watching the log, I am seeing values for KR (Knock retard). Is this where you are seeing the timing lost?
    2003 Chevy S10 4.3L LU3 LS1B Auto
    48 LB injectors
    Race Proven Motors 2114 intake
    T70 turbo.
    Oct 2008
    looks like you're right. is it just me or does it not look like i should be running alot more timing? i mean with the older engines i've worked on at 2.5 psi of boost i should be at about 28 degrees not 15. my afr are about 10.8 to 1 at wot. any thoughts?
    May 2008
    There's a lot of things that could cause it like distributor incorrectly set, noisy valvetrain, exhaust hitting the frame. I'll try to take a look at it when I get home, but it will be very tough to troubleshoot without wideband in the log files.
    Do you have any information like whether it is intercooled, compression ratio, or other engine modifications?
    48 LB injectors
    T70 turbo.
    Oct 2008
    some more info on my truck. the engine is a 572 cu bored .030" and stroked to 604 cu. it has raylar alumium heads cnc ported and polished. the engine was built for me by Raylar engines and i had them lower the compression ratio to 9.0 to 1. they custom ground the cam the same as their na racing engine but added more exhaust duration for the turbos. i have an intercooler and water/methanol injection. 72lbs/hr injectors at 62psi
    (about 82lbs/hr). the turbos are sx400 each will move enough air to suport about 700 hp. i do have an LM-01 but it won't recognize the serial port in it so i can't log with it until i get it fixed but the display on it says the afr is about 11.0 to 10.6 at wot. i also have a pyro on each bank which has helped with the tuning and i have an autometre narrow band o2 sensor for tuning cruse areas of the VE table. i can't find much info on tuning with egt's but i try to keep them under 1350 deg f at low load. wot the egt's will go to 1600 deg. on the exhaust side i have headers going into 3" than both 3" into 4" to the remote mounted turbos. duel 4" leaves the turbos. intake is duel 5" to the turbos and than into 3.5" to the 3" intercooler and into 3" to the 3" throttle body. i have built all of the truck myself and can't remember all the mods along the way but still plan to upgrade the intercooler to 3.5" and put a larger throttle body onto it. the fuel system is a 3/4" from the fuel tank to a weldon fuel pump to 1/2" to a custom fuel rail with weldon regulator. i'm shooting for a 1000hp on premium with good driveablity. i have only run 3 psi of boost and am taking the tuning slow. i've got a reasonable idle at 750 rpm and tuned to 3psi but still working on the ve table and timing maps to get them better but just haven't had enough time to work on it lately. the ignition is msd coils one per cylinder the same as the ls-1. the engine is brand new and just broken in and put synthetic oil in it for the first time. i relocated the intake air temp sensor to the 3" down stream of the intercooler. i've been working on this truck for 7 years but have had efi live for only a couple of months. the ability of the programming is great but a little overwelming at times with so many variables and it's hard not to make more than 1 change at a time. thanks for any help.
    Sep 2007
    Hey 496, I'm not an EFI expert either, but am working on a similar setup (HP numbers) for a friend. It looks like the PCM has used the 'engine protection mode' timing {B5921} and then reduced it by the KR number and finally reduced it further by the boost reduction table. Just a quick glance - I'll look further. In my case, I'm learning the software on a cammed LS1 engine with a supercharger that is intended for the 7 liter, fully built engine that will replace it so even though I'm flirting with disaster and over 20deg of timing at 5psi, I still have not triggered knock. I'm wondering if you're getting false knock too. The last thing to consider is the 'burst knock' parameters {B6212} - despite it's name, it just pulls timing based on airflow change programmed in {B6210}. That one has gotten me before.
    Again, I'm learning too and had a minute to look over your logs with my Sunday morning coffee. Hope some of this leads to solution for you.
    Oct 2008
    i looked at b6210 and it could be pulling the timing. do i need burst knock or should i zero the burst knock retard table? or maybe increase the burst knock delta air mass table? as for the b5921 my operating sys doesn't seem to have it. i used the stock 496 truck tables as a starting point so i haven't changed these tables yet. thanks for the info.
  1. Car is pulling timing
    Last Post: February 27th, 2010, 04:55 AM
  2. Pulling timing for nitrous
    By SRT10KLLR in forum Gen IV V8 Specific
    Last Post: November 13th, 2009, 04:52 AM
  3. Pulling Timing - No idea why
    By Camaro SS in forum Custom Operating Systems
    Last Post: May 12th, 2009, 02:50 PM
  4. Pulling vaccum at WOT
    By cmitchell17 in forum Gen III V8 Specific
    Last Post: September 30th, 2007, 02:55 PM
  5. Pulling timing
    Last Post: August 27th, 2006, 06:40 AM
