Results 1 to 10 of 16
Thread: No A/F!!
    Default No A/F!!
    I have done the updates, (seemed to all go OK) But now I cant log my air fuel through serial. All I get is controller not found.
    Need help ASAP!! Have car sitting on dyno since Friday with still no fix.
    I have
    bootware 2.06.02
    16oct08
    firmware 2.06.05
    28oct08
    __________________
    Nov 2006
    you need to select the WBO2 through the V2.
    F4 > F1 > F1 scroll down to WO2 type and select your WBO2 press Ok.
    LC-1 WBO2
    Thats all been done. It still says no controller found. It did work until the latest update.
    What WB...?
    innovate lm1
    Lorenz,
    Did you set all of these:
    - serial pids = yes,
    - com in = wide 02,
    - com out = wide 02,
    - wo2 type = innovate,
    - wo2 fmt = both,
    - wo2 data = AFR & EQ.
    Lorenz,
    - com in = wide 02,
    - wo2 fmt = both,
    Yes,
    I even tried changing them and then setting them back to what you have posted.
    And you have the serial AFR cable plugged in...?
    And this same cable worked before...?
    I pm'd Paul... he may be on his way to SEMA which starts tomorrow.
    Yes its plugged in. Yeah its worked for a good while, used it daily.
