Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
Thread: Nothing worse then failing emissions on the 31st
  1. #11
    The Service Manual says this (for 2001 Camaro/Firebird):
    Inspection/Maintenance (I/M) System DTC Table
    DTCs Required to Set System Status to YES
    AIR
    DTC P0410
    DTC P1415 or P1416
    Catalyst
    DTC P0420 or P0430
    EVAP
    DTC P0440
    DTC P0442
    DTC P0446
    DTC P1441
    Oxygen Sensor
    DTC P0133 or P0153
    DTC P1133 or P1153
    DTC P1134 or P1154
    Oxygen Sensor Heater
    DTC P0135, P0141, P0155, or P0161
  2. #12
    Dec 2007
    Joecar you are awesome! When I get home this afternoon I'm going to plug back in the Rear O2's and turn the MIL's back on, and see what that does for me.
    THANKS SO MUCH EVERYONE!!!
    -CoryF
    2001 Camaro SS #2070
    -K&N FIPK, P/P TB, 227/231 .614/.617 111+4, UD Pulley, LT headers, OFY, Dumped 3" Exhaust, !AIR, KONI 4/4, Spec 3+ w/ Aluminum Fly Wheel, 4.10's, Custom EFILive Tune
  3. #13
    Set "MIL" and "Not Reported" to make the readiness tests say "Ready".
  4. #14
    Nov 2003
    In Arizona you get one free "Not Ready". Note the left center of the inspection report. I was in compliance even with the EVAP "Not Ready".
    I have had problems with the EVAP diagnostic in the summer. This test will not run if the IAT or the ECT is above 86 deg F. They must also be within 16 degs of each other. Make sure your cold start meets these requirements.
    Good Luck
    LEC
    1964 Red Corvette Coupe, 365Hp, 4Spd, 4:11 Positraction, side exhaust. Original Owner.
    2002 MYellow Corvette Coupe, 447Hp, Auto, 2.73:1 Positraction, Magnuson Supercharger, B&B Catback, K&N Filter, ACI Cowl Induction Hood and Rear Spoiler.
  5. #15
    Dec 2007
    Okay so I finally found some time to look at my tune. lol I was a long day. It seems that all of the O2 codes were set to MIL/NOT REPORTED, but the AIR ones were set to NO MIL/NOT REPORTED. So in the morning I will load this tune and try the GM driving deal and hopefully that'll fix my emissions problems.
    -CoryF
  6. #16
    Jan 2006
    Might want to lower B4205 to enable closed loop fueling also.
    John
  7. #17
    Dec 2007
    Quote Originally Posted by ssvolvo View Post
    John, should I put that back to the stock temperatures? Or set them at a temperature that I think I will reach during a driving cycle?
    Thanks,
    -CoryF
  8. #18
    Do they do the sniffer...?
  9. #19
    Dec 2007
    Joe, no sniffer. They just plug in and check the MIL light, the Readiness tests.
    -CoryF
  1. New emissions laws
    By GMPX in forum Lounge
    Last Post: June 5th, 2009, 05:33 AM
  2. RR is failing as soon as it tries to update realtime data
    By TFZ_Z06 in forum RoadRunner Real-Time PCM Emulator
    Last Post: April 25th, 2009, 01:25 PM
  3. Success with Dec 31st Update?
    By Goldfinger911 in forum FlashScan V2 BB Logging
    Last Post: January 4th, 2008, 11:06 AM
  4. Emissions codes?
    By NewV in forum Gen III V8 Specific
    Last Post: April 3rd, 2007, 03:29 PM
  5. emissions
    By ZL1Killa in forum General (Petrol, Gas, Ethanol)
    Last Post: March 28th, 2006, 09:07 AM
