Results 1 to 3 of 3
Thread: What are the exact steps for running an LC-1?
    Jun 2005
    Default What are the exact steps for running an LC-1?
    I have it all hooked up and calibrated.
    My question is... in my EFILIVE software, what do I activate and where do I find it. My EFILIVE instruction book is way to vague.
    I have tried to use and can not get it to read on my EFILIVE. I have changed some settings, but it is not working.
    Please help.
    '71 chevelle
    Twin turbo ls1
    1000 HP 93 octane street car!
    96 lb injectors
    Sep 2003
    The instruction manual was pretty straight forward for me
    and this post was stickied right above your post. Easy to follow directions
    http://www.efilive.com/forum/viewtopic.php?t=1145
    Most of your questions have been answered at least 3 times on the board use the search feature and i am pretty sure it will steer you in the right direction..
    EFILive - The Single version of the Truth
    Larry - HumpinSS
    The LC-1 is now pre-configured in EFILive (V7.3) so you don't need to set up your own calculated PIDs.
    Select and log the following PIDs:
    {EXT.AD1} or {EXT.AD2}
    {CALC.AFR_LC11} or {CALC.AFR_LC12}
    {CALC.BEN_LC11} or {CALC.BEN_LC12}
    Whether you choose "1" or "2" as the last digit in the above PIDs is determined by which pin you connected your LC-1 "Analog 2" wire to on FlashScan.
    If you connected the LC-1 "Analaog 2" wire to FlashSCan pin "E", then use "1", if you connected the LC-1 "Analaog 2" wire to FlashSCan pin "C", then use "2".
    Make sure you connect the Analog ground to PIN "D" on FlashScan.
  1. IAC steps??
    Last Post: August 31st, 2008, 10:38 PM
  2. how bad is 140 IAC steps?
    By gcross in forum Gen III V8 Specific
    Last Post: January 29th, 2007, 07:15 AM
  3. IAC steps.
    By Big Kahuna in forum General (Petrol, Gas, Ethanol)
    Last Post: January 9th, 2007, 11:16 AM
  4. IAC vs IAC EA vs steps
    Last Post: March 23rd, 2006, 04:54 PM
  5. Tuning steps
    By jfpilla in forum General (Petrol, Gas, Ethanol)
    Last Post: March 1st, 2005, 01:37 PM
