Results 1 to 10 of 20
Thread: tuning vy v6 commodore
    Nov 2008
    Default tuning vy v6 commodore
    hi i have efi live v4 software and cable from when i owned a vr i am just wandering can i use the same cable and software to tuning my vy commodore. if it is possible would anyone have a vechile file for the vy commodore in .xml format. thx
    The VY 5.7 liter requires EFILive V7.x and can be scanned and tuned using FlashScan V1 or V2.
    The VY 3.8 liter can only be scanned by EFILive V4. WE don;t offer tuning for VY 6 cylinders.
    Nov 2008
    if you can use efi v4 to scan vy v6 commodore does anyone have a vehicle file or know where i can get it from
    Oct 2004
    We haven't moved these across to the new site yet. Here is a link to the file: http://209.132.211.34/download_V4xml/gmh-vy6.zip
    Andrew
    EFILive Crew
    Nov 2008
    thx. you have all been very helpful
    Sep 2007
    Default confirm VR cable works
    Hi,
    I've got a V8 VY Monaro and have a 9 pin RS232 ALDL cable (which I used to use with my V6 VR).
    Could you confirm this serial cable will work with the VY V8 Monaro and EFI Live V7?
    Thanks.
    John
    Quote Originally Posted by johnnyk View Post
    Hi,
    Thanks.
    John
    No, the VY V8 is not supported with the ALDL cable.
    You must use FlashScan V1 for GenIII engines or FlashScan V2 for GenIII and GenIV engines.
    Sep 2007
    Hi Paul,
    Thanks for the quick response. Can I re-confirm that EFI Live V7 will not work with the VY V8 Monaro?
    I need to purchase the hardware solution (FlashScan) ?
    On the software side:
    EFILive V7 is the correct software for VT series II thru to the latest model VE commodore V8s.
    EFILive V4 is compatible with VN, VP, VR, VS and VT series I (V8s). And for VN, VP, VR, VS, VT, VX and VY V6's
    On the hardware side:
    EFILive V7 software uses FlashScan V1 or V2. V1 supports VT-II thru VZ (non HSV) and V2 is for ALL VT-II to current V8 commodores.
    EFILive V4 software uses various ALDL interfaces but NOT FlashScan.
    We intend to add software to the next version of V7 (called V8 - not to be confused with V8 engines) that allows you to scan and log ALDL vehicles using FlashScan V2.
    Hope that is not too confusing.
    Last edited by GMPX; March 1st, 2009 at 05:35 PM. Reason: Sorry Paul, had to correct your V6 models, VZ V6 is CAN.
    Sep 2007
    I think so
    What you're saying is that I need EFI Live V7 as well as the hardware (FlashScan) ?
    Is there any way I can avoid purchasing the hardware, but use V4 or V7 of EFILive to read limited data (I'm interested in seeing stored fault codes, and viewing the oxygen sensor's signal).
  1. vs commodore ute
    By VS97EV in forum EFILive V4
    Last Post: August 4th, 2009, 07:26 PM
  2. Commodore
    By Chevy366 in forum Lounge
    Last Post: July 13th, 2009, 04:57 PM
  3. new commodore
    By odd boy in forum E37, E38 & E67 PFI ECM's
    Last Post: May 4th, 2009, 10:23 PM
  4. VX and VY commodore
    By Thumper in forum Gen III V8 Specific
    Last Post: February 8th, 2009, 11:48 AM
  5. Commodore vx II V6 on LPG
    By Mike :) in forum General (Petrol, Gas, Ethanol)
    Last Post: May 19th, 2006, 11:17 PM
